Valve tick???
Old Apr 25, 2006 | 03:35 AM
bignatesan's Avatar
bignatesan
Default Valve tick???
After seeing the pictures of that bent rod and busted rocker arm, I am a bit more concerned about the tick that has started in my 302. It is fairly noticable once the engine is warm and I am certain it is coming from the #4 cylinder. I pulled all of the plugs and #4 is much darker than the rest but no oil or fouling. So my question, is this the kind of sound usually resolved by a lash adjustment or should I plan on blocking out a Saturday afternoon to pull the heads?
Big Nate
Old Apr 25, 2006 | 12:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Valve tick???
Sounds like #4 lifter is a little loose. I would try adjusting the valves to see if that resolves it before pulling heads.
Old Apr 25, 2006 | 02:36 PM
slickman's Avatar
slickman
Yup, good advise..
ORIGINAL: Soaring
Old Apr 25, 2006 | 05:22 PM
JBradley500's Avatar
JBradley500
whenever i try to answer a question...someone else has already answered. DARN YOU.
Old Apr 25, 2006 | 05:27 PM
slickman's Avatar
slickman
Well, what you can do is give us you're MACH1 for free and we will shut up and never answer aother question.. How's that, sound good??? [sm=bounceybounce.gif][sm=drooldude.gif][sm=goodidea.gif][sm=happybounce.gif][sm=yeahsmile.gif]
ORIGINAL: JBradley500
Old Apr 25, 2006 | 05:49 PM
JBradley500
tempting...maybe tomorrow we can make a deal.
Old Apr 26, 2006 | 01:31 AM
bignatesan's Avatar
bignatesan
Thanks for the advice guys! Just let me drive that Mach 1 for an hour and I'll shut up.
Big Nate
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
Sixer4Life
Sep 28, 2015 07:05 AM
