eninge drain plug
Old Apr 26, 2006 | 07:43 PM
66ckurt's Avatar
66ckurt
Default eninge drain plug
were is it? the coolant drain i mean.
Old Apr 26, 2006 | 07:54 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: eninge drain plug
The petcock for draining the radiator is on the bottom of the radiator. Look on the driver's side first. Here is mine. http://pic10.picturetrail.com/VOL326.../142377000.jpg
Old Apr 26, 2006 | 08:00 PM
66ckurt's Avatar
66ckurt
i got that one but is there not one on the block its self i need to take off my intake manifold and its still got coolant in it? If theres not how would i go about taking it off with out getting coolan in my heads?
Old Apr 26, 2006 | 09:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Drain the petcock on the rad and leave it open. Start the car and let it run for a few minutes for the pump to draw all the fluid out of the block and throw it into the rad where it will drain. The only other way to drain the block is to take out a freeze plug.
Old Apr 26, 2006 | 09:09 PM
66ckurt's Avatar
66ckurt
lol ya the running of the engine is not an option
Old Apr 26, 2006 | 09:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
Then pop out a freeze plug.
Old Apr 26, 2006 | 09:47 PM
ownsaglock's Avatar
ownsaglock
Arent there pipe plugs (3/8)cast into the sides of the block? I know Ive seen them on a engine I cant remember if it was a ford.
Edit: I looked at a pic of my 67 289 and one is on the side of the engine opposite of the oil filter. Small square pipe plug towards the front of the engine. There is another one on the oil filter side of the engine back towards the transmission.
Old Apr 27, 2006 | 06:54 AM
66ckurt's Avatar
66ckurt
isn't the freeze plug like on the front of the engine right under the cylinder headers, ive never heard of a pipe plug what are the differences?
Old Apr 27, 2006 | 10:40 AM
ownsaglock's Avatar
ownsaglock
The freeze plugs are along the side of the engine and are recessed into the block. They are smooth and about a 1 1\2-2" in diameter. They are under the cylinder heads. You cant miss em. And as soaring said pulling one will empty the block. The pipe plugs are small threaded square plugs that stick out from the block. Im not sure if all years of small bocks have them but I know mine does.
Old Apr 27, 2006 | 10:44 AM
popper's Avatar
popper
Yea, there's two block coolant drain plugs (square head) on the 289. One is passenger side front - right next to the bolt that holds alternator ground/ battery ground/ transmission lines bracket. The other is driver's side rear.
