eninge drain plug
Old Apr 27, 2006 | 02:50 PM
usmcdevilmp's Avatar
usmcdevilmp
Default RE: eninge drain plug
ORIGINAL: 66ckurt
lol ya the running of the engine is not an option
i wouldnt pop out a freeze plug. try taking off your belt and spin the water pump by hand if you dont want to run the engine.
Old Apr 27, 2006 | 06:20 PM
66ckurt's Avatar
66ckurt
can't screw up my timing at this point
Old Apr 27, 2006 | 06:21 PM
66ckurt's Avatar
66ckurt
and plus i think the engine holds in the coolant until it heats up, so i think its gotta be the plugs
Old Apr 27, 2006 | 06:36 PM
66ckurt's Avatar
66ckurt
lol okay that square plug found it its amazingly tight, so how do you take out a freeze plug?
Old Apr 27, 2006 | 08:13 PM
Riven02's Avatar
Riven02
I wouldnt knock out a freeze plug. Just drain it though the block drain holes as stated above. They will be VERY tight, they are pipe threaded. Just get a cheater pipe or something.
Old Apr 27, 2006 | 11:48 PM
ownsaglock's Avatar
ownsaglock
ORIGINAL: 66ckurt
Hit it with some PB blaster,let it soak for 15 min or so and try it.The longer you wait the better.
Edit:Im talking about the pipe plug
Old Apr 28, 2006 | 05:53 AM
Magiarn71's Avatar
Magiarn71
Why don't you just siphon it out? I've changed intakes before and never drained the block from a plug, and definitely not by punching a freeze plug.
Old Apr 28, 2006 | 08:44 AM
66ckurt's Avatar
66ckurt
ya i went with the drain plug, and ya deffinatly was tight just hit it with some move it let it set and bam off, also didn't realize they used silicone on the intake as well as the valve covers as a gasket( that was fun). Thank you for all your guys info it was it would have been me unbolting 30 different bolts to figure it out. Now if u guys can help me with my other obsticle my father he thinks im wasting to much money on the car, this coming from a guy who had a hemi dart when he was my age, and since im 18 i can't he has the power to take my car away[:@]
BOB ROME
Jul 26, 2023 01:54 PM
jerrytubes
Oct 23, 2015 12:11 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
wraith777
Sep 28, 2015 10:49 AM
