automatic transmission cooler lines
Old May 1, 2006 | 11:53 PM
z3080's Avatar
z3080
Default automatic transmission cooler lines
I'm doing an engine swap on a "68 coupe with a 289 engine and an automatic tranny.I cant break the tranny cooling lines from the tranny. My question is this, is there an alternative to these copper lines like braided steel maybe? Where can I get something better?
The lines are so tight that i'm starting to strip the fittings and I'd like to replace them if I can >.....THANX
Old May 2, 2006 | 12:13 AM
mustanglover66's Avatar
mustanglover66
Default RE: automatic transmission cooler lines
you can get corbon steel or stainless steel from NPD
Old May 2, 2006 | 01:52 AM
THUMPIN455's Avatar
THUMPIN455
Try tightening it just a little, it should break lose. Then wiggle it back and forth untill it comes free. Be careful not to twist or kink the lines. Some PB Blaster works wonders on them, and most of mine are rounded off my vise grips. A good line wrench that will fit in there only comes off a truck, like SnapOn, Mac, or MATCO.
Old May 2, 2006 | 04:31 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Thumpin has got the trick. that should work for you. Your lines should be steel not copper. Copper should not be used it is too soft.
Old May 2, 2006 | 09:51 AM
popper's Avatar
popper
I had to drop my transmission before I could finally get some vice grips on the upper line. That is one tight fit!
Old May 2, 2006 | 12:12 PM
Twister's Avatar
Twister
be sure to use a line wrench so you do not round the heads
mtgldr
Feb 3, 2024 09:00 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Sep 16, 2015 07:53 PM
LivingInThePast
Sep 16, 2015 12:20 PM
