T-5 or Toploader
Old May 4, 2006 | 11:28 AM
highhilleer's Avatar
highhilleer
Default RE: T-5 or Toploader
ORIGINAL: Twister
let's look at it another way, how much in gas will it take to make up the cost of a new bellhousing, clutch kit, clutch fork, tranny, tranny crossmember and a modified drive shaft?
So I whipped together a small Excel worksheet to estimate the payback period. You need to enter the cost of the mod, the cost of gas, miles driven per year, estimate the mpg before and after the mod. It computes the annual gas savings in both gallons and dollars and the years for the return on your investment. You can down load it from:
http://www2.cemr.wvu.edu/~wwwasph/temp/
Of course the big trick is to estimate how a modification will affect your mileage.
You could also use the calculator for the analysis of a new car purchase. For example use the cost difference between a hybrid and conventional car as the "cost of the mod", then enter the mpg for each. (For any economist in the audiance, I know about discounting for the time value of money, just thought it was more sophisticated than needed for this situation.)
Old May 4, 2006 | 12:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
I would have thought it would have been more than a year or so, but I guess not.
Not only are you saving moolah on gas, you are also saving the wear and tear of the engine if you cruise on the freeway a lot with a T-5 instead of the toploader. And, since the toploader needs work anyway, why not change to the T-5?
Old May 4, 2006 | 12:53 PM
highhilleer
Yea, an over drive is almost a must have if you're doing much driving. How many new cars these days do not have OD? I cannot think of any.
Old May 4, 2006 | 08:50 PM
Rorin67's Avatar
Rorin67
ORIGINAL: highhilleer
So I whipped together a small Excel worksheet to estimate the payback period....
Highhilleer - this spreadsheet is amazing! Great job. [sm=drooldude.gif]
Glen - may I suggest adding this to the FAQs section for future reference?
Old May 4, 2006 | 08:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
It is there now as we speak.
Old May 5, 2006 | 12:05 PM
highhilleer
ORIGINAL: Soaring
Soaring, the spreadsheet is on a temporary space that is subject to disappear at anytime. I would be pleased if you could arrange a more permanent home for it. I'm not looking for any pride of authorship issues or anything like that. Just making it available for anyone who would find it useful is enough. Send me a pm if you want to discuss.
Highhilleer.
cobra427302
Jun 25, 2004 07:19 PM
wadeb3
May 21, 2004 11:13 AM
TheGmKiller331
Feb 17, 2004 06:58 AM
my86lx
Jan 22, 2004 10:23 AM
mcgyver8062
Dec 31, 2003 08:56 PM
