1969...
Old May 4, 2006 | 02:36 PM
SuperHoss's Avatar
SuperHoss
Default 1969...
I have been in the possession of a set of slightly used 1969 351W heads for a while now and I am preparing them (cleaning, new valves, springs, decked, etc...nothing major) for installation on my 289. Will these heads effect my compression negatively?
Old May 4, 2006 | 02:41 PM
tyler72's Avatar
tyler72
Default RE: 1969...
Yep. You could put a blower on it to bring it back up though!
Old May 4, 2006 | 02:57 PM
SuperHoss's Avatar
SuperHoss
Default RE: 1969...
A good idea, but not for a daily driver.
Old May 4, 2006 | 03:24 PM
RSRXION's Avatar
RSRXION
Default RE: 1969...
Actually... take a look at your heads and see if the head casting is C9OE-6090. If so they are dandys ! They have the smallest combustion chamber of any factory Windsor head. They'll help you a fair amount on performance but you'll need to pay attention to your timing and fuel grade to avoid detonation and the ever present risk of destructive pinging. I'm sure you've already installed hardened valve seats for use with modern day ( lead free ) gasoline. Trust me on this one, Dean
Old May 4, 2006 | 06:13 PM
SuperHoss's Avatar
SuperHoss
Default RE: 1969...
I was VERY careful to seek out 69-70 351 Windsor heads because of the performance they are supposed to give. I am not cutting any corners on these, I learned the hard way about trying to save a dime on engine parts. Hardened valve seats are a given as well as new springs, screw-in rocker studs, replacement valves, and a good cleaning by experts. Nothing major is being done because these are going on a 289, and its probably got around 250 HP so it's not super strong.
Old May 4, 2006 | 09:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 1969...
250 HP with a 289 is pretty strong. Heck, even the HiPo's are only rated at 271. I am lucky to get 190 out of my 289.
Old May 4, 2006 | 09:50 PM
JBradley500's Avatar
JBradley500
Default RE: 1969...
best 190 hp car youve ever owned?
Old May 4, 2006 | 10:02 PM
SuperHoss's Avatar
SuperHoss
Default RE: 1969...
I have various mods, most of which came from the previous owner:
Aluminum Hi-Rise Intake, 750 Holley, Headers, Electric Fan, H-Pipe, slightly stronger cam, .030 bore, and it was supposed to be balanced (this is the only mod that I don't believe, the rest I have proven). The power is at the flywheel, which means my rear-wheel power is unknown. In the near future I am going with some roller lifters, roller rockers, roller timing-chain, the 351W heads...but don't get the wrong impression I'm more into my suspension that I am my engine. I have a few improvements with sway-bars, shocks, and other cool suspension toys.
Old May 5, 2006 | 04:08 AM
SuperHoss's Avatar
SuperHoss
Default RE: 1969...
I also have an Accel Billet-Proof Distributor, a low OHM Coil, 10 degrees timing advance and soon to add aluminum water-pump and oil cooler.
Ramblen Randy
Sep 14, 2018 06:30 PM
kennekeuh
Feb 10, 2013 07:43 AM
Toddman0025
Aug 5, 2006 11:51 PM
