Correct bolts for these brackets???
Old May 5, 2006 | 06:43 PM
earlymustang's Avatar
earlymustang
Default Correct bolts for these brackets???
Anybody know what the correct bolts are for these brackets? They are for 65 conv. support tubular braces, one on each side. The two side by side are different from the one that attaches the brace?
[IMG]local://upfiles/14974/ED4D1925DCFF4CD48EB796AA697DA2FA.jpg[/IMG]
Old May 5, 2006 | 10:21 PM
1965MustangFastback's Avatar
1965MustangFastback
Default RE: Correct bolts for these brackets???
Here you go, hope this helps!
[IMG]local://upfiles/16936/F9E1D1FC4C2B46F6A1AA5523F45C9FDD.jpg[/IMG]
Old May 5, 2006 | 10:24 PM
1965MustangFastback
Here's another picture
[IMG]local://upfiles/16936/4375A92306DB4C468B81AA5DDFF6491F.jpg[/IMG]
Old May 5, 2006 | 10:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
The second pic is what my coupe engine bay looks like. Do all the 65 verts have that long brace going to the cowl as in the first pic. ? If so, the bolts appear to be the same as the fender bolts. Matt, do you have those long braces?
Old May 5, 2006 | 11:07 PM
earlymustang
65's use the long braces and 66 used shorter ones. I have those same pictures. I need to find the bolts b/c I don't have the correct ones. Soaring, they are different from the fender bolts (as far as I know). The bolt that holds the tubular brace is close to the fender bolts but the other two are different.
Old May 6, 2006 | 12:01 AM
Soaring's Avatar
Soaring
I ♥ Acer
Then, the cowl bolts shoud be the same as your shock tower to cowl brace bolt.
Old May 6, 2006 | 12:02 AM
1965MustangFastback
Hey Early did you try AMK bolts, they might have them!
http://amkproducts.com/
Looks like it might be part # F-112 from AMK Products
Old May 6, 2006 | 12:53 AM
earlymustang
sounds like that is it, thanks
ORIGINAL: 1965MustangFastback
Old May 6, 2006 | 01:05 AM
6mustang6's Avatar
6mustang6
I have never seen those braces. Are they on the verts only? i have seen a 66 vert without them.
Old May 6, 2006 | 01:14 AM
1965MustangFastback
I think 64 1/2 and 65 only had them!
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
