steering column pull
Old May 7, 2006 | 12:43 AM
BillyBobJoe's Avatar
BillyBobJoe
Default steering column pull
i wanted to pull the steering column from the donor car but after i removed the bolts there was some type of wire or cord attaching it to a jumble of other crap under the dash. i couldnt get a good look because of dust and stuff falling in my eyes and the mix of randomonium from the previous owners...half the wires arent attached to anything, they just hang there. Anyway, the cable looked liek it went to a white cylinder or square like object behind the ignition and wiper control. I couldnt get the cable out and I was wondering if you all could tell me how to remove it. Thanks in advance.
Old May 7, 2006 | 03:27 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: steering column pull
What year of stang are you working on?
Old May 7, 2006 | 03:33 AM
Twister's Avatar
Twister
65-67....you need to pull it out through the engine bay...yank EVERYTHING out of the divers side of the bay first...then pull it out the top, above the radiator
Old May 7, 2006 | 02:40 PM
BillyBobJoe
nope its a 69. And i've already got it loose from the box and unbolted from the dash. There is just this one little cable that won't let it go. Hence the sig. lol
Old May 8, 2006 | 08:45 AM
nelson's Avatar
nelson
Its a almost flat connector - it's got a slight curve and connects the steering column functions (indicators, horn etc) into the wiring form via a flat cable. It's just a matter of unplugging it. Use a bit more force and it will separate.
Old May 8, 2006 | 06:43 PM
BillyBobJoe
nope...i disconnected that...this is a single cable about 3mm thick toward the middle of the column.
Old May 8, 2006 | 07:06 PM
Soaring's Avatar
Soaring
I ♥ Acer
Don't know much about the 69's, so just a wild guess here. If it is a cable, it could possibly be two things. One, is the fresh air vent cable, and two would be a hood release if the 69's had those. Again, this is just a guess.
Old May 8, 2006 | 10:22 PM
BillyBobJoe
hm....i dunno...ill get back udner their later. i ran out of light and couldnt really follow it to well but it didnt look like a hood release
CS2007
Jun 25, 2019 09:45 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
