Patriot headers
Old May 9, 2006 | 11:35 AM
darth289's Avatar
darth289
Default Patriot headers
Have any of you guys ran Patriot headers on a small block in a 68 mustang? We're currently in the process of switching from a FE to a 302, and I was wondering about these headers. The price is right. Any advice is appreciated!!
Old May 9, 2006 | 12:48 PM
Fastback Guy's Avatar
Fastback Guy
Default RE: Patriot headers
I have a friend who has a set and he seems pretty happy with them.
Old May 9, 2006 | 02:36 PM
darth289's Avatar
darth289
Thanks for the reply. Does he run a stick or an auto? This car has a top loader in it.
Old May 9, 2006 | 03:43 PM
Fastback Guy
He runs an automatic.
Old May 9, 2006 | 03:47 PM
darth289's Avatar
darth289
Since they're mid length's, surely the auto won't make a difference compared to a stick would it? It still has the z-bar set up and hasn't been swapped to a cable yet.
Old May 9, 2006 | 08:42 PM
SuperHoss's Avatar
SuperHoss
I have a set of Tri-Ys from them(ceramic coated)...for clearence of the Z-Bar, I had to buy the HiPo version of it (this is a 66), and everything bolted right up.
Old May 9, 2006 | 11:08 PM
1965MustangFastback's Avatar
1965MustangFastback
Hey Superboss when you change the Z bar did you have to change anything else? I want to do the Tri-Y's in my car and I was told the same thing, unless I spend $500 for the Hooker Headers 61111 model , I really dont want to spend that much for Headers only!
Old May 10, 2006 | 01:23 AM
SuperHoss's Avatar
SuperHoss
It would be wise to inspect the bar that goes from the z-bar to the fork and the rod from the pedal to the z-bar, if they are worn heavily then they need to be replaced. The bearings, clips, and felt bushing need to be replaced on the z-bar as maintainence(no stuff like new stuff), but at a bear minimum, the z-bar is the only thing to replace. The HiPo z-bar is the only part different from stock Ford equipment, it was initially designed for the original 65-66 GT-350 because of the Tri-Ys used by Shelby. The bottom part of the arm is shorter than the stock z-bar, this is the only difference.
I got the 2.5 inch collectors and the 1.5-1.75 primaries (bigger than standard Tri-Ys) with the coating for just over $300 with sales tax; the ceramic coated Hooker Headers were just over $500(they're nice, but I don't want them that bad).
Old May 10, 2006 | 09:00 AM
darth289's Avatar
darth289
I suppose we'll try these headers and see what happens. He wants to put the Clippster model in, so hopefully there isn't any clearance issues! No matter what I guess it won't be as bad as the FE!!
Thanks guys
Old May 24, 2006 | 09:59 AM
darth289's Avatar
darth289
Well, I just figured out that these headers won't work!! If any of you have a set of good headers for a decent price laying around, please let me know!
Thanks
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
