vacuum line to modulator help.
Old May 12, 2006 | 03:38 AM
Gun Jam's Avatar
Gun Jam
Default vacuum line to modulator help.
Hello
The vacuum line on my modulator broke off from the modulator. There is still part of the rubber sticking out from the modulator and the other half is stuck on the vacuum tube.
How does that vacuum line fit to the modulator? Does the modulator come with one installed or what? There is no nipple that I can see it looks flush on the face of the modulator except where there is some vacuum line rubber edges sticking out.
How is it suppose to connect?
Thanks
Gun
Old May 12, 2006 | 04:22 AM
THUMPIN455's Avatar
THUMPIN455
Default RE: vacuum line to modulator help.
Pull the rubber hose from both ends. The nipple is recessed into the modulator. The line should butt against the nipple and the rubber hose seals the joint. Once you get the old rubber out of there, it will be self explainatory. Got any questions after that, let me know..
ya might want to change the top rubber line connection as well..
Old May 12, 2006 | 01:09 PM
Gun Jam's Avatar
Gun Jam
Ha
awesome I was worried the nipple broke off or something. Just pull out the old section and im set!
Thanks Ill give it a shot in a bit
Gun
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
