Bad Headlight Switch?
Old May 12, 2006 | 05:39 AM
65 coupe's Avatar
65 coupe
Default Bad Headlight Switch?
So i went to go drive my 1965 coupe tonight and when i went to turn on the headlights they flickered for a second and then turned off. Then i decided to see if the high beams worked and they do! What could be the reason my normal headlights won't work but the high beams will? I was thinking a bad headlight switch and just wanted to see what you guys thought. This is my first post and you guys seem to know quite a bit about classic mustangs so i though i would look for some help on this one. Thanks for any info!
Old May 12, 2006 | 08:35 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Bad Headlight Switch?
That would be the place to start
Old May 12, 2006 | 08:39 PM
ideal_mustangs's Avatar
ideal_mustangs
Sounds like a dimmer switch problem to me.
Old May 12, 2006 | 08:44 PM
67t5ponycoupe
good point
StalkerGT
Nov 28, 2015 03:09 PM
Colin Ringle
Sep 15, 2015 09:27 PM
TfcCDR
Sep 14, 2015 12:08 PM
Wombatnation
Sep 13, 2015 09:16 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
