exhaust manifolds ???
Old May 12, 2006 | 11:34 PM
CompYellow69's Avatar
CompYellow69
Default exhaust manifolds ???
What is a decent header dimension? obviously the larger the better but what did the stock 351W's come with and what should be the minimum from a performance standpoint?
Old May 13, 2006 | 12:18 AM
paladin_1888's Avatar
paladin_1888
Default RE: exhaust manifolds ???
351W engines have pretty small valves so they can only process so much air, most any good tube header will breathe fine with a winsor head unless you have a lot of head mods. tube size of 1 5/8 in. will do ok, but the bigger the tube the more torque, use smalle tubes for higher rpm, but lower torque.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dokilar
15
Oct 16, 2015 08:13 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 24, 2015 09:18 PM
