what a rear end mess
Old May 13, 2006 | 09:44 PM
paladin_1888's Avatar
paladin_1888
Default what a rear end mess
started to do a rear end swap today and found a good mess, the old 9" housing had an 8" detroit locker inside, now to do the swap back to a 9" locker will have to change axles and driveshaft, guess I should have paid attention to the old addage"look before you leap"
Old May 13, 2006 | 09:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: what a rear end mess
Tell us why you want to change it. Is the 8" locker not working?
Old May 13, 2006 | 09:56 PM
paladin_1888
The 8" was making a terrible noise, found out why...some of the parts were left out and some small pieces were ground to little chunks and powder. gears were ok, but no springs or spring block
Old May 13, 2006 | 10:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think if it was mine, I would start all over with new guts to the 9" housing you already have.
Old May 14, 2006 | 10:22 PM
fast66's Avatar
fast66
By no means am I an expert on diffs, but, I have been looking for a locker for my 8", and the part numbers for the 8"are the same as the 9" ones. As long as they are both 28 spline axles, the kit is the same. Not all 9" came with the 31 spline axles, so you may not have an issue.
Old May 14, 2006 | 10:31 PM
THUMPIN455's Avatar
THUMPIN455
Would you mind posting some pics of the 3rd member from the front?
Old May 14, 2006 | 10:39 PM
paladin_1888
Dont have any pics readily available, solved the problem, neightbor came by and sole me another 8" detroit locker, now have two 9" rears and a rebuildable 8" locker, got gears everywhere
Old May 14, 2006 | 10:43 PM
paladin_1888
We also had a really bad hail storm here today in the midst of all the rear end swap stuff
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
96stang3.8
Sep 10, 2015 06:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 1, 2015 08:16 PM
