Over heating on Highway
Old 05-14-2006, 02:00 PM
UBY289
UBY289's Avatar
Default Over heating on Highway
Hi I have 67 Coupe 289 that over heats on the Highway put not in the city.I have flushed the rad (2 core), new stat, hoses ,belts. There is a shroud and a 17 1/2 or 18 inch 7 blade clutch fan. pump look new from last motor re build.Think the fan and clutch may be wrong,I think it belongs to 24 inch Rad for 390 or 428 from what I found.Any ideas.
UBY289 is offline
Old 05-14-2006, 03:07 PM
Soaring
I ♥ Acer
Soaring's Avatar
Default RE: Over heating on Highway
I'm running a 17 inch 6 blade mechanical fan on my 289, so that should be the correct size. Your clutch fan may not be working right at highway speeds. However, if I were you I would upgrade that old 2 row rad up to at least a 3 row. You might also consider an electric fan with an upgrade to the alternator if it continues to give you trouble.
Soaring is offline
Old 05-14-2006, 03:11 PM
usmcdevilmp
usmcdevilmp's Avatar
well at highway speeds, it doesnt matter if you even have a fan or not. The speed your going is has plenty of air going thru the radiator. A fan isnt going to do anything going that fast, unless your revs are up. Its just there for the ride until you get into city speeds.
usmcdevilmp is offline
Old 05-14-2006, 03:13 PM
redstallion
redstallion's Avatar
you bottom hose may be collapsing. If it is then you can either replace it or put a spring in there,
redstallion is offline
Old 05-14-2006, 03:19 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: usmcdevilmp
True dat!
Soaring is offline
Old 05-14-2006, 04:01 PM
slickman
slickman's Avatar
Yup, that could be.. If you're temp is okay around town and only heats up on the highway, I would look at the bottom hose as was stated and also think about changing that two row to a three row... You also may want to think about a high flow water pump.
ORIGINAL: redstallion
slickman is offline
Old 05-14-2006, 04:04 PM
tylerdru
tylerdru's Avatar
He is in canada so i think i may be able to get away with a 2 row for now. put a spring in the bottom hose.
tylerdru is offline
Old 05-14-2006, 04:06 PM
UBY289
UBY289's Avatar
where do I get a spring for the hose?
UBY289 is offline
Old 05-14-2006, 04:08 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: tylerdru
Canada or not, if he is overheating on the highway then he is overheating. He doesn't have enough cool water running through the block at fast enough rate. Two ways to help cure that is to increase the volume of water by adding a larger radiator, and to add a high volume pump to push more through.
Soaring is offline
Old 05-14-2006, 04:09 PM
myshifter
I ♥ Acer
myshifter's Avatar
lower hose collapse
myshifter is offline
Quick Reply: Over heating on Highway
