Distributor: Points vs. No Points
Old May 15, 2006 | 11:52 AM
ThInIcE67's Avatar
ThInIcE67
Default Distributor: Points vs. No Points
Im doin a restoration on a 67 coupe with a 289 and a few engine mods (bore, exhaust, carb, etc.). Im not looking to race it or anything but i was thinking of going with the electronic distributor instead of the classic points. it needs to be replaced either way, so does anyone know the pro's and con's of each one, and which brands I might want to check out?
Old May 15, 2006 | 12:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Distributor: Points vs. No Points
You say your distributor needs replacing? Look into the pertronix system. Get a stock dizzy and the pertronix module and flamethrower coil. Any way you go, do not go back to the points. That is the weak link in the ignition system.
Old May 15, 2006 | 12:11 PM
Twister's Avatar
Twister
if you do get a Pertronix, keep a set of points and a condensor in the glove box, just in case. There is nothing like having a hot rod part fail in Podunk, Iowa and the local speed shop has more tractor parts than car parts....
Old May 15, 2006 | 12:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I have my points in the tool box in the trunk. I put in the pertronix a few months back, and (knock on wood) have not had a problem with it yet. The 289 starts and runs much better than it ever has. In fact, it starts so quick, I don't even hear the starter turn over.
Old May 15, 2006 | 01:08 PM
289FB's Avatar
289FB
I also have petronix for over a year with no problems..but I carry an extra set in case I need , cost a little more that a set of points but is much faster to replace on the road.
Old May 15, 2006 | 01:31 PM
ideal_mustangs's Avatar
ideal_mustangs
Could you still run the stock coil with the pertronix, or would that defeat the purpose? I still have the stock yellow top coil.
Old May 15, 2006 | 01:48 PM
Twister's Avatar
Twister
they do better with a hotter coil, buy their black coil, and spray paint the top using "school bus yellow"
Old May 15, 2006 | 02:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: ideal_mustangs
Yes you can, but then you won't be able to gap the plugs wider than 0.032 or so if you don't use the flamethrower coil.
Old May 15, 2006 | 02:32 PM
289FB's Avatar
289FB
Is that (coil and spark plugs gap) for the petronix II??? I have the "old" petronix version with a regular coil and works great..(I don't remember the gap on my plugs I have to chek that)
Old May 15, 2006 | 03:06 PM
67Rally's Avatar
67Rally
Has any of you gone the route of a duraspark? I am completing the change over in mine along with an MSD 6AL & Blaster2 coil.
