fuel pump
Old May 16, 2006 | 05:32 PM
rouschfan's Avatar
rouschfan
Default fuel pump
what is your all's oppinion ? Is an electric fuel pump better than the mechanical ?
Old May 16, 2006 | 08:21 PM
Scott H.'s Avatar
Scott H.
Default RE: fuel pump
depends on the application. I prefer a mechanical pump in a naturally asperated, street driver, carb application.
I'd save the electric for forced induction and EFI.
A common component that is missed with electric fuel pumps is an inertia switch that kills the pump in case of an accident (like comes stock on EFI vehicles). Another viable way to do this is either a vacuum switch or oil pressure switch that kills the pump when the engine is not running.
Old May 16, 2006 | 08:25 PM
Soaring's Avatar
Soaring
I ♥ Acer
Scott nailed it. What engine, etc,. are you running?
Old May 17, 2006 | 12:00 AM
rouschfan's Avatar
rouschfan
actually it is in a 76 ranchero, it has a 460 with edelbrock carb. an intake, someone has replaced the mechanical with an electric,seem's as though it is not getting enough fuel.So i am thinking of going back to the mechanical.
Old May 17, 2006 | 12:05 AM
THUMPIN455's Avatar
THUMPIN455
In a street driven vehicle that doesnt get raced just put a mechanical back on it.
If you plan on "spirited" driving or "acceleration tests on a closed course" then an electric near the tank is best, with the aforementioned switches. Many times a car that will run a low 12 wont get enough fuel from the mechanical pump simply because it is pulling the fuel all the way from the tank, as opposed to being pushed by an electric.
Unless its pretty badazz, a mechanical will work fine.
Old May 17, 2006 | 12:09 AM
rouschfan's Avatar
rouschfan
thank's guy's appreciate the help !
Old May 17, 2006 | 12:13 AM
6mustang6's Avatar
6mustang6
i like electric ones for the quick start up's. gas is already at the carb..... i have a mechanical on all of my cars, but one day..... i will get an electric one.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
