What do I need to install kickdown cable?
Old May 17, 2006 | 01:19 AM
19stang66's Avatar
19stang66
Default What do I need to install kickdown cable?
I am ordering a kickdown cable from NPD but just now realized that I need more than just the cable to hook it up. What are these parts called in the following pictures and are those the only other parts i need to install the cable?
Also, on the first picture there is the bolt with the two sides that are flat and with two sides with threads on them. Does a nut go on this bolt to hold on that bracket or what goes there?
I dont have the neutral saftey switch on my car. Do I need to install that for the linkage to work?
Old May 17, 2006 | 08:52 PM
palerider's Avatar
palerider
Default RE: What do I need to install kickdown cable?
Check out summit racing. Just installed one on my 1970 mustang. Since you have a holley there is also a bracket you'll need to hook it up. They can tell you at summit. Also if you have the old throttle linkage will need to replace - it will get in the way. I got and aftermarket chrome cable kit from autozone that hooked up no problem - summit has them too.
So you will need:
1. Lokar kickdown for C4 trans
2. Holley adaptor bracket
3. New throttle cable
Pretty easy intall.
http://store.summitracing.com/egnsea...=KeywordSearch
Old May 17, 2006 | 10:59 PM
19stang66's Avatar
19stang66
So I need this kickdown bracket for my Holley to work with the kickdown? --> Kickdown bracket Where does this attach to?
Here is the throttle linkage I have now, can I still use this or will I need a different linkage?
Old May 18, 2006 | 07:19 PM
19stang66's Avatar
19stang66
Old May 18, 2006 | 07:55 PM
slickman's Avatar
slickman
Here is what you need. I did this on my 66 with my C4.
PN: KD-20C4HT Lokar link
[IMG]local://upfiles/26659/9DE75D4CE7D64E69873947755284203E.jpg[/IMG]
And this
PN# SRK-4000 Lokar link
[IMG]local://upfiles/26659/3B4A88BCFCA44FF5B5314DC1391DB055.jpg[/IMG]
Old May 18, 2006 | 08:24 PM
19stang66's Avatar
19stang66
Do you have any detailed pictures of your install slick?
Old May 18, 2006 | 08:28 PM
slickman's Avatar
slickman
No, I can take some pics when I go down to the garage. But, the install is very simple and the directions are very clear that comes with the Lokar.
ORIGINAL: 19stang66
Old May 18, 2006 | 08:29 PM
19stang66's Avatar
19stang66
Thanks! Oh will I need a new throttle cable to? Or will the one in my pictures still work?
Old May 18, 2006 | 08:35 PM
slickman's Avatar
slickman
Nope, you will need a new cable.
ORIGINAL: 19stang66
Old May 18, 2006 | 08:38 PM
19stang66's Avatar
19stang66
ummm tips on which one? Any cheap ones out there that will work? This whole kickdown deal seems to be adding up faster than I thought.
