Ignition problem...REALLY weird...
Old May 21, 2006 | 06:14 AM
Craig67's Avatar
Craig67
Default Ignition problem...REALLY weird...
Well when I go to turn off my car today, I turn the key and the accessories turn off, but the engine keeps running! Everything turns off except the engine. I had to turn it off by letting the clutch out and stalling it that way...what is the problem here? I have no clue!
Old May 21, 2006 | 10:19 AM
6mustang6's Avatar
6mustang6
Default RE: Ignition problem...REALLY weird...
hmmm. Maybe your switch is bad. and unless you have rewired the car, there could be a short. Whatever it is, it is giving the coil power with the switch off. If worse comes to worse. rewire the coil. Oh, and disconnect your battery or it'll be dead, or screw up your coil.
Old May 21, 2006 | 01:54 PM
JBradley500's Avatar
JBradley500
it wont shut off at all, or does it just keep running for a couple of seconds?
Old May 21, 2006 | 02:01 PM
68Midnight's Avatar
68Midnight
This was happening to me a couple weeks ago. It was a short for me. But it could be your ignition switch, solenoid, or a short.
Look really hard for the short. They hide pretty good.
Old May 21, 2006 | 06:17 PM
Craig67's Avatar
Craig67
Well I'm REALLY bad when it comes to electrical, so can you explain like exactly where I need to check? The starter solenoid is the one over by the starter, right? And where do I check for shorts and the ignition switch? Is the ignition switch under the dash?
Sorry for asking for so much detail, but I really don't understand electrical very well, lol.
Old May 21, 2006 | 06:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JBradley500
Yeah, if it eventually shuts off, then you have a dieseling problem. If the engine acts like you never turned off the key at the ignition, then the ignition switch is worn out and needs to be replaced.
Old May 21, 2006 | 06:48 PM
CompYellow69's Avatar
CompYellow69
mine did that, ignition switch was bad...
Old May 21, 2006 | 06:55 PM
Craig67's Avatar
Craig67
Okay, that's what I was thinking because I was looking for shorts at the coil/starter solenoid and didn't see anything.
Old May 21, 2006 | 06:58 PM
P Zero's Avatar
P Zero
ORIGINAL: Soaring
+1
Old May 21, 2006 | 07:28 PM
Goauburn50's Avatar
Goauburn50
Mine use to do the same thing. I also am Electrically ignorant. I replaced parts until the problem stopped. The Ignition switch was the last part I replaced before the problem was fixed. It is Very simple to change. Just follow the directions. Good Luck. Happy Drivin.
