EFI 351 in a 65 - Hood Clearance ??
Old May 24, 2006 | 01:35 PM
timsheldon's Avatar
timsheldon
Default EFI 351 in a 65 - Hood Clearance ??
Hey All,
Has anyone here stuffed an EFI 351 into a 65?? Wondering if it will fit under a stock hood ??? The donor is a 96 Bronco and the mounts are the early style with the motor mount stud pointing straight down if it matters .
tim
Old May 24, 2006 | 10:17 PM
69mach1377's Avatar
69mach1377
Default RE: EFI 351 in a 65 - Hood Clearance ??
I think bronco/truck motors have taller intakes, so beware.
Old May 25, 2006 | 12:10 AM
Decurion's Avatar
Decurion
A bronco intake belongs on a bronco. get a gt40 style upper (or explorer upper intake) and go to ford motorsport for the matching lower. youll thank me.
Old May 25, 2006 | 11:08 AM
timsheldon's Avatar
timsheldon
Soooo If I go with the Motorsport Lower and GT40 /Explorer Upper will this fit under a stock hood ???
for some reason I have only seen carbs on 351 /65 swaps, which led me to wonder if perhaps there was a problem with clearances...
Old May 25, 2006 | 04:11 PM
usmcdevilmp's Avatar
usmcdevilmp
buy a cowl induction hood. they fit really good and youll have a reason to have one- unless your building a sleeper.
Old May 25, 2006 | 11:02 PM
69mach1377's Avatar
69mach1377
Snowball effect...
Old Jun 19, 2006 | 12:12 PM
slvrbllt's Avatar
slvrbllt
I just finishing one up,I found an edlebrock clone on e-pay that the guy had 3\4 of an inch
milled off between the upper and lower. I have just enough room to close the hood without the engine hitting it when it is tourqued. It's a lot of work, but it is worth it.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
Ipaman
Sep 22, 2015 07:01 AM
