which dizzy is best
Old May 26, 2006 | 02:10 PM
acidrain088's Avatar
acidrain088
Default which dizzy is best
im looking for a new distributor for my 66 289. i have the original stock one in there right now and i want one that will just connect right in (no fancy wiring) what would you guys suggest? msd, mallory? and also what coil to go with it.
Old May 26, 2006 | 03:13 PM
slickman's Avatar
slickman
Default RE: which dizzy is best
I have asked this very same question of the forum to see what people have been using. There are many mfg out there but, all I can tell you is what I'm going to use. I'm going with a FORD PERTRONIX BILLET DISTRIBUTOR for my 289.. Everyone has there own reasons to use others like MSD, mallory or some others. For simplicity and cost effectiveness, you could use a PERTRONIX module in place of the points. Simple and easy to install..
ORIGINAL: acidrain088
Old May 26, 2006 | 07:08 PM
Smothers's Avatar
Smothers
I'm no expert, but I like the Mallory Uni-lite I'm using on my recently rebuilt 289. No points, no controll box and easy install.
http://store.summitracing.com/partde...0&autoview=sku
[IMG]local://upfiles/26569/534DF8FEBA7E437E84BCCA632D05E77B.jpg[/IMG]
Old May 26, 2006 | 07:21 PM
muggsy's Avatar
muggsy
That's one clean machine you got there...i like it!
Old May 26, 2006 | 07:33 PM
Smothers's Avatar
Smothers
ORIGINAL: muggsy
Thanks muggsy! [sm=smiley9.gif]
........or maybe you were referring to slickman's ride. His car is ok I guess.
[sm=roll.gif]
Old May 26, 2006 | 08:49 PM
slickman's Avatar
slickman
[sm=alcoholic.gif]
ORIGINAL: Smothers
ORIGINAL: muggsy
[sm=roll.gif]
Old May 26, 2006 | 10:03 PM
67Rally's Avatar
67Rally
Slickman,
The subtle changes you made to that '66 really make your stang stand out. What's the prognosis on the white dye-job on the black vinyl? Any chance it will bleed thru? The wheels are very clean.
Old May 26, 2006 | 10:33 PM
slickman's Avatar
slickman
Thanks for the kind words.. So far no sign of any problems at all with the black showing through. Still looks as nice as the day I did it. Its all the small details that make a car stand out. I try to pay attention to that when I can.
ORIGINAL: 67Rally
Slickman,
Old May 27, 2006 | 01:44 AM
JBradley500's Avatar
JBradley500
Davis Unified Ignition...
Old May 27, 2006 | 06:04 AM
66stangstable's Avatar
66stangstable
I personally like msd, I installed the msd 6AL box, Distributor, and Blaster 2 Coil on my 302 in my 66. But if you are going for inexpensive it is not the way to go. But is fairly simple to install and definitely worth the money. But this is just another opinion, good luck with your upgrade.
