Backfire
Old May 27, 2006 | 01:35 AM
civilbrown's Avatar
civilbrown
Default Backfire
I was working on my '65 289 A code, I put in a Pertronix Ignitor and Coil. When I put the Cap back on and start it up the idle is much higher and now is a little rough. Do I need to reset the timing? Also like a moron I tried to start her up and I forgot to put the Distributer Cap back on. I gave it gas and a little choke. When IO figured it out and put the cap back on, I started her and it blew my eardrums and my mufflers out! What else did this damage?
Thanks for any help!
Old May 27, 2006 | 11:38 AM
6mustang6's Avatar
6mustang6
Default RE: Backfire
You could have blown out your power valve..... i think those are on holleys. Did you set the gap right for the pertronix? You may need to adjust the timing again.......
Old May 27, 2006 | 04:19 PM
civilbrown's Avatar
civilbrown
I believe its the autolite 4v. I took it out last night for a drive it runs strong except for the loud exhaust. I set the gap on the pertronix to the 0.03" spec. When I put it in Park and let it idle it bounced from 500 to 650 on the tach. Do I set the initial timing to 6?
Thanks
Old May 27, 2006 | 10:34 PM
6mustang6's Avatar
6mustang6
thats what they say for timing. I usually advance it a tad. I think your idle is alittle low isn't it? I think it should be more around 850 when in park, but im not sure. You did use the plastic feeler guage included with the pertronix right? i metal one can mess it up.
Sean
Aug 15, 2004 03:50 PM
Disgustang
Jul 27, 2004 09:43 AM
Obsol3te
Jul 26, 2004 08:42 PM
spuckie
Nov 21, 2003 05:51 PM
tchamber
Nov 9, 2003 05:47 AM
