I need a radiator
Old Jun 1, 2006 | 08:48 PM
randy78045's Avatar
randy78045
Default RE: I need a radiator
ORIGINAL: Soaring
If you are going to spend that kind of money for a brass/copper core rad, you may as well step up to the Giffin aluminum rad.
My radiator IS aluminum...
Old Jun 1, 2006 | 09:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
OOPS, sorry about that Randy. There are a lot of aluminum rads out there, and I just didn't recognize that brand. Aluminum rads are great for dispensing heat, but not necessary with daily driver applications.
Old Jun 1, 2006 | 09:26 PM
67t5ponycoupe's Avatar
67t5ponycoupe
3 core aftermarket high flow $179 http://www.mustangdepot.com/OnLineCa...g/radiator.htm
Old Jun 1, 2006 | 09:29 PM
randy78045's Avatar
randy78045
ORIGINAL: Soaring
Your probably right, but many older engines have mineral buildup, etc an the extra cooling certainly wont hurt... if ya wanna spend a few extra $$$...
Old Jun 1, 2006 | 09:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: randy78045
ORIGINAL: Soaring
I hear ya, and yes if it is an old engine with deposits in the water jacket, then the cooler the water is going through there the better. Assuming the block is clean, then an aluminum rad is not necessary for a daily driver. And, if it is not, then it is time for a block cleaning and an overhaul. I have noticed though, that most modern cars are running with aluminum 2 row rads and with high volume airconditioners, and they seem to run just fine with the heat thing.
Granatelli Sales
Jan 20, 2020 12:34 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Beerman309
Sep 19, 2015 01:16 AM
MusicCity615
Sep 12, 2015 07:05 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
