Help! Engine stutters under load
Old Jun 3, 2006 | 09:39 PM
daviddanna's Avatar
daviddanna
Default Help! Engine stutters under load
Hi all,
I have a 67 289 auto that's been sitting for a few months. Today i went to drive it and noticed a pretty significant stuttering of the engine but only when in gear. In neutral i can give it full throttle and everything feels fine. I've tried adding newer gas and some fuel system cleaner and i've sprayed some carb cleaner and messed around with the timing.
Any body have any ideas? please help!
Thanks,
Dave
Old Jun 3, 2006 | 09:46 PM
hammeron's Avatar
hammeron
Default RE: Help! Engine stutters under load
You may want to check the fuel filter & air filter
Old Jun 3, 2006 | 09:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
You need to drain your gas tank fully, and replace the fuel filter in the tank as well as the in-line fuel filter. You will most likely have to overhaul your carburetor. You have an old gas problem. Varnish........
Old Jun 4, 2006 | 12:05 AM
daviddanna's Avatar
daviddanna
I tried bypassing the inline fuel filter and removing the airflter but no change. I guess i'm off to drain the fuel tank and overhaul the carb. thanks for the replies!
Dave
Old Jun 4, 2006 | 03:19 AM
Gun Jam's Avatar
Gun Jam
If those suggestions dont help then a new fuel pump is probably in order
Gun
Old Jun 4, 2006 | 03:27 AM
67t5ponycoupe's Avatar
67t5ponycoupe
See what the plugs look like. Also could be the accelerator pump on the carb.
Old Jun 4, 2006 | 12:21 PM
slickman's Avatar
slickman
Everything said could be the problem as well as cross arching in the distributor cap. So, you need to drill down and find out if its fuel or electrical.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
