door adjustment
Old Jun 4, 2006 | 04:47 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: door adjustment
got a pic of the door jessie?
Old Jun 4, 2006 | 04:53 PM
slick66stang's Avatar
slick66stang
ok so im not that great with my computer yet. what do you think about my car
Shifty101Easy's Avatar
Shifty101Easy
we need pics to be able to tell....
Old Jun 4, 2006 | 04:57 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
its a good project except for the door situation u say ur having very easy to work on these early cars and they are cheap to maintain!but try and load up some more pics to photobucket then geterate the html and change the img to image in the brackets and they will show up
Soaring's Avatar
Soaring
I ♥ Acer
Old Jun 4, 2006 | 05:21 PM
slick66stang
ok so i cant figure it out but this is suppose to be a view of the driver side and a view of my passenger side and you can see the window and door not aligning right
Old Jun 4, 2006 | 05:23 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
go to ur photobucket home page and cut and paste the link so i can go there
Old Jun 4, 2006 | 05:29 PM
slick66stang
http://s67.photobucket.com/albums/h283/CLASSICLOVER66/
Old Jun 4, 2006 | 05:44 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i think ur probably missing one of the rollers and the door glass is sitting cockeyed from this and when u roll it down it putting pressure on the rod inside the door that operates the latch link to the rollers they are cheap! like a 1.15$ but u need two per door u have to remove the door panel and they are retained by a little clip that pushes in it! pull the clip and remove the arm for the window put the new clip back in and replace the clip! hope fully this will take care of it if! make sure u do this with the window at the bottom of the door so u dont drop the glas and break it!
http://www.mustangunlimited.com/itemdy00.asp?T1=3135+01 its worth a try also pick up a copy ofmustang 1964 1/2-1973 restoration guide it has a bunch of exploded pics of how the car fits together!!
Old Jun 4, 2006 | 05:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
I had to turn my head sideways to see the pic, but it appears you just need to adjust the window. Take off the door panel, and see if there is something bent that can either be straightened or replaced with a new part.
