door adjustment
Old Jun 4, 2006 | 05:57 PM
  #21
slick66stang's Avatar
slick66stang
Default RE: door adjustment
the only thing bent is the lock rod retainer for the door handle where it meets the locking mechanism. when i roll down my window the bottom of the door latch assembly moves inward and toward the front of the car
Old Jun 4, 2006 | 06:00 PM
  #22
rmodel65's Avatar
rmodel65
Yukon Cornelius
i think u have a broken/missing roller
Old Jun 4, 2006 | 06:06 PM
  #23
slick66stang
do you think thats all? how do i get the bottom of the door to come in and the whole door be flush with body
Old Jun 4, 2006 | 06:11 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
By the pictures, it appears your door is flush with the body door frame. You can loosen your hinges and try to better align it that way, then tighten back up the hinges. But, first you need to take off the door panel and have a look inside the door to see if something is either missing or bent.
Old Jun 5, 2006 | 04:59 AM
  #25
Shifty101Easy's Avatar
Shifty101Easy
yeah, pop the panel off and make sure everything is greased and on the right things......my windows were thouroughly ravaged......like roll em up...let go of the roller....1....2....CRASH! it would slam back down into the door....then the other one would just jam halfway down.......so weird....i just took them out and got them all regreased and on the right track and it worked great now.
jerrytubes
Oct 23, 2015 12:11 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
