Door panel removal?
Old Jun 4, 2006 | 03:29 PM
baddog671's Avatar
baddog671
Default Door panel removal?
How do I remove the door panels on my 67coupe? I started prying on it and a clip popped off, but then it started tearing...do I need any tools or something for this, or just need to know the proper way to do it?
Old Jun 4, 2006 | 03:56 PM
mustanglover66's Avatar
mustanglover66
Default RE: Door panel removal?
you need a door pannal removeal tool you can get it at any auto parts store. you push it in under the clips and then pry them lose one at a time
Old Jun 4, 2006 | 03:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
Quite often it doesn't matter how much to try to be careful, that old cardboard will rip anyway. Consider new panels if you screw up more of them.
Old Jun 4, 2006 | 04:16 PM
bradleyb's Avatar
bradleyb
For the price of new panels, you probably want to buy new ones. Take a putty knife and run along the outside of the door panel so you can identify where the clips are located and then pull on both sides next to the clip. If you are doing interior, there is a great book by Art TRantafello called Mustang interior restoration guide for 1964 1/2 to 1970.
Old Jun 5, 2006 | 02:43 AM
baddog671's Avatar
baddog671
I thought new panels were expensive...?
Old Jun 5, 2006 | 04:54 AM
Shifty101Easy's Avatar
Shifty101Easy
i think u can get two for like 50 or 60 something bucks....i THINK i saw that....no promise there lol.
Old Jun 5, 2006 | 09:06 AM
daves67's Avatar
daves67
I just ordered two door panels and two arm rests for $97. The arm rests cost as much as the panels. Might as well get some panel clips too if you order panels. They are like 15 cents each.
Old Jun 5, 2006 | 12:39 PM
baddog671's Avatar
baddog671
Cool thanks. Maybe I was thinking of those aluminum inserts that are around 100 or something each. Mine are kinda old anyways so Ill probably just tear em out. Are the new ones made of sturdier stuff?
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
