Manually rotate engine?
Old Jun 5, 2006 | 02:56 PM
68Midnight's Avatar
68Midnight
Default Manually rotate engine?
How do you do it?
Old Jun 5, 2006 | 03:00 PM
SpudRacer's Avatar
SpudRacer
Default RE: Manually rotate engine?
Use a 1/2 rachet, a socket (13/16"?) and a short extension, then put the socket on the BIG bolt in the middle of the crankshaft pulley and turn clockwise as needed. If it's an automatic transmission, you'll need to have the transmission in neutral or it won't turn
Hope that helps.
Tom Bryson City, NC
Old Jun 5, 2006 | 03:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Depending on the compression of the engine, you may need to pull the plugs.
Old Jun 5, 2006 | 03:05 PM
68Midnight's Avatar
68Midnight
Perfect, thank you.
Old Jun 5, 2006 | 03:27 PM
68Midnight's Avatar
68Midnight
Well the only reason I want to turn it is to get to the fly wheel bolts. But 13/16 was too small....So I have to go buy another size up.
Old Jun 5, 2006 | 03:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
It's a 15/16. The 13/16 is for the lug nuts.
Old Jun 5, 2006 | 04:44 PM
68Midnight's Avatar
68Midnight
correct.
Thanks.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Mustangmalo
Sep 6, 2015 05:22 PM
