but the block, technically, is the same? you can take and old block and put new internals in it without a hitch right?
yes just the new blocks are drilled and tapped for the hydraulic roller lifter hold down. You can use a retro fit kit for an old block if you want to run a hydraulic roller cam but the available cams in the retrofit category are all small base circle cams which are terrible at high rpm, really tough on valvetrain
the blind man has been given sight. i see now. so it's better to buy a newer block witch accepts rollers? got it!
really doesnt matter as you can use a solid roller lifter which each two lifters are linked together, new roller 302 motors the lifters are not linked together rather they use a bolt down holder that looks like a spider and holds the lifters in their bores
