valve adjustment procedure
Old Jun 6, 2006 | 12:42 AM
jroseman's Avatar
jroseman
Default valve adjustment procedure
Could someone tell me a where i could find the valve adjusting procedure for the 289?
Old Jun 6, 2006 | 12:47 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: valve adjustment procedure
Unless you have a K code, you have hydraulic valves. Here is the procedure.
http://raceabilene.com/kelly/hotrod/valveadj.html
Old Jun 6, 2006 | 12:53 AM
jroseman's Avatar
jroseman
thanks,
i'll need that when i pull the head to check the piston and rings. can i tell if the oil ring was installed upside down? i'm grabbin' for straws here.
Old Jun 6, 2006 | 12:55 AM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: jroseman
thanks,
nope, why do you suspect it?
Old Jun 6, 2006 | 12:57 AM
Soaring's Avatar
Soaring
I ♥ Acer
Why? Are you burning oil? Need some more information such as the mileage on that engine since the last overhaul.
Old Jun 6, 2006 | 02:34 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Didn't know there was such thing as upside down on oil rings. That is why I let the experts do the short block.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
