1965 fastback weatherstripping install prices $$$
Can anyone suggest around how much they would thing it would cost to install already purchased weather stripping. I bought the entire kit and might not need it all but if I where to install everything in the kit can someone give me an estimate.
thanks
thanks
A few hours with that and felts. I usually figure out an hour a door... Thats stripping it and gluing it back on. The best way to do the trunk is to remove it and turn it upside down. You should do this your self, it's really easy. All you need is some acryliclean/ mineral spirits a plastic scraper, heat gun or blow drier and a couple of tubes of weather stripping glue. Take your time and it will be just fine. Good luck!
Someone posted pics of doing the felts. I think it was Plainsman. I will ad to the instructions he posted. In order to get you window all the way down you need the take out the rubber bumper in the door where the window bottoms out. This was in the instructions. What was not is there is a fan shapped gear that has a U shapped bracket that is a stop for the gear. If you look for the fan shapped gear you will find the bracket. I think the felt would be you hardest replacement. Also when you do your trunk finish with the seam at the bottom or towards the back of the car. You might check Mustang Monthly for any archive How Tos
Good luck, Walt
Good luck, Walt
