oil pressure
Old Jun 7, 2006 | 08:51 PM
6mustang6's Avatar
6mustang6
Default oil pressure
I still have the stock guage. When the car is warmed up, the guage is actually reading below the little line on the low side. That is getting real close to low. This is starting to get me worried, because it has just started doing it.
Old Jun 7, 2006 | 08:53 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: oil pressure
what oil are u running for summer time run some 20-50 on these old school engine but if u have at least 10psi for every 1000rpm then ur fine!
Old Jun 7, 2006 | 11:19 PM
mustanglover66's Avatar
mustanglover66
worn rod and main bearing will cause that. Been there done that a high volume oil pump will help also
Old Jun 7, 2006 | 11:30 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you are positive your gauge is correct, then the low oil pressure is caused by worn oil and pressure rings. Time for an overhaul if that is the case.
Old Jun 8, 2006 | 01:09 AM
6mustang6's Avatar
6mustang6
well, i wouldn't know for sure about the guage. I have just replaced the voltage regulator. IT wasn't too long ago, the oil pressure was alright. It has just slowly been declining over the past year or two. I believe my heads are deterioating.
Old Jun 8, 2006 | 01:17 AM
69mach1377's Avatar
69mach1377
Do not trust the stock gage for something like this...only a good mechanical gage will tell you the truth. Stock gages are little better than warning lights.
Old Jun 8, 2006 | 01:28 AM
6mustang6's Avatar
6mustang6
yeah, i knew somebody would say that. Im thinking about installing a mechanical or a another electric one., but i dont have anywhere to put it. I have an underdash stereo.
Old Jun 8, 2006 | 01:56 AM
myshifter's Avatar
myshifter
I ♥ Acer
look at all avenues before declaring the problem http://sbftech.com/index.php/topic,84.0.html
Old Jun 8, 2006 | 12:17 PM
6mustang6's Avatar
6mustang6
I was thinking it could be the oil pump. I was planning on dropping the oil pan, when i do my cam, intake, etc. upgrades. Ill put in a hi performance one. Hopefully that will bring it up, but first, i need to get a guage on there, so i know where i am at.
Old Jun 9, 2006 | 01:26 AM
69mach1377's Avatar
69mach1377
There's always the column mount, old skool style.
