oil pressure
Old Jun 9, 2006 | 01:40 AM
mustanglover66's Avatar
mustanglover66
Default RE: oil pressure
I had the same problem once I bought a cheap mechanical gage and hooked it up temporarily to trouble-shoot the problem, I just took one screw out from under the dash and mounted it there. Also keep it mind the pump only provides oil volume the rod and main bearings make the pressure. with these old stangs its easy to drop the pan and change them, just take the crossmember under the pan off and it will drop right out.
Old Jun 9, 2006 | 08:23 AM
6mustang6's Avatar
6mustang6
What cross member? that is good info. I didn't know that the main bearings made the pressure.....
Old Jun 9, 2006 | 08:24 AM
6mustang6's Avatar
6mustang6
oh, and i already got a tach on my steering column.
Old Jun 9, 2006 | 01:28 PM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: 6mustang6
any small orifice will make pressure. Picture if you were able to put a straw on your faucet in your sink, the pressure would be much greater at the end of the straw then were its connected to the fuacet.
Old Jun 9, 2006 | 01:55 PM
6mustang6's Avatar
6mustang6
Yeah thats good to know. BUT, i dont want to know that, because that means by bearings are worn out.
Old Jun 10, 2006 | 11:40 AM
69mach1377's Avatar
69mach1377
First things first, hook up the gage and let us know pressure at idle, cold and hot and same for 3000 rpm while cruising around.
Old Jun 10, 2006 | 12:50 PM
6mustang6's Avatar
6mustang6
yeah, i will do that soon and get back with you.
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
ccdguy
Sep 19, 2015 05:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
