Realigning my bumper question.
Old Jun 10, 2006 | 07:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Realigning my bumper question.
When I put on new bumpers, the front one never did seem to align correctly. The driver's side corner just isn't aligned properly as you can see in the pic. Is there something I can do to get it to be straight with the world?
[IMG]local://upfiles/10034/0F839BD2FDDE49B998B2893B6FE0DD27.jpg[/IMG]
Old Jun 10, 2006 | 07:38 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default RE: Realigning my bumper question.
Is it possible its upside down? (I really dunno maybe it can only go one way, I'm just throwin that out there)
Old Jun 10, 2006 | 07:43 PM
baddog671's Avatar
baddog671
looks fine to me
Old Jun 10, 2006 | 08:00 PM
Soaring's Avatar
Soaring
I ♥ Acer
I guess I am just **** retentive. However, if you look at it closely, you will see that it rises up as you go from the front of the bumper toward the 289 emblem. The other side is not that way. No, it's not upside down.
Old Jun 10, 2006 | 08:43 PM
67t5ponycoupe's Avatar
67t5ponycoupe
If the other side is the same then it is an alignment problem. If it is not it is a twisted bumper.
Old Jun 10, 2006 | 09:13 PM
baddog671's Avatar
baddog671
I dont know, unless u are really ocd about it, it looks fine. CJPonyParts sells slightly twisted bumpers for 10 bucks...
Old Jun 10, 2006 | 09:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 67t5ponycoupe
Man, can you guys not read? I just said the other side is not the same. It may very well be a twisted bumper as it is a repro. OK, I guess I will just either live with it, or try to change the geometry on the underside hook up.
Old Jun 10, 2006 | 09:51 PM
67t5ponycoupe
I no can read man. i are not a good ritter iether. Hey Glenn if you pull it off and lay it on a flat surace it will tell you if it is twisted. You can twist them back into shape with brute force and ignorance.
Old Jun 11, 2006 | 12:33 AM
EmperorOfChicken
I figured it out, your whole car is tilted slightly leaning to the right, the bumper is acctually straight and the car is off! AHA! You are welcome.
Old Jun 11, 2006 | 01:27 AM
ideal_mustangs's Avatar
ideal_mustangs
Do the 66's not have the little bracket on the fender that the bumper mounts to?
