frame rails and torque boxes help!
Old Jun 13, 2006 | 05:58 PM
351foxstang's Avatar
351foxstang
Default RE: frame rails and torque boxes help!
ORIGINAL: 1965MustangFastback
In the 64-66 Mustangs only the Convertibles had torque boxes, In 1967 and up they where standard in all models! In both my 1967 Cougar there was only one on the driver side only, not sure if this is true for the Mustangs!
yep, 67 mustangs had only the drivers side. in 68 and up they were on both sides of the car.
Old Jun 13, 2006 | 06:01 PM
Clu7ch's Avatar
Clu7ch
here's some pics, first three are the bumper supports. the inner one is the center. and there is a set on the other side also. the grill (unless you mean the "fangs") bolts into th efront clip, there are no real supports for that. the fangs bolt onto the center supports for the bumper. the third pic shows the poll support on the drivers side that was busted off when a garbage truck ran a red light and my friend hit him.
the last 2 are the grill, you can see on the top on the far ends there are the bolt locations and the bottom near the middle are the other locations.
[IMG]local://upfiles/33080/4D727ECEB2EA4EEC8264E521D3245213.jpg[/IMG]
[IMG]local://upfiles/33080/DB13566B866F4FD591E2C231C70B7B73.jpg[/IMG]
[IMG]local://upfiles/33080/0687186D74CB40A7B4CA4B03B88D749D.jpg[/IMG]
[IMG]local://upfiles/33080/3236FF1D8F354674B3C142732292FB48.jpg[/IMG]
Old Jun 13, 2006 | 06:02 PM
Clu7ch's Avatar
Clu7ch
well, the last pic was too big. here it is
[IMG]local://upfiles/33080/6F593A56A21542829ED8ADAB13DBAFBA.jpg[/IMG]
Old Jun 13, 2006 | 06:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, there are six on my 65. The two fender supports, the two tubular supports, and the two inner bumper supports that are right above the bumper guards.
Old Jun 13, 2006 | 06:27 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Soaring
do you have pics of the fender supports? are those the things about a foot or so from the fire wall on the outside of the engine comp roughly where the shock towers are?
Old Jun 15, 2006 | 03:37 PM
coda618's Avatar
coda618
I read a post saying that 67's only had a driver side torque box. That is the case with mine. It happens to be an early '67. No passenger TB. I thought I was nuts or someone removed a rusted one and never replaced.
Is there any value in adding one on the passenger side? Worth the trouble?
Old Jun 15, 2006 | 05:02 PM
Smothers's Avatar
Smothers
I saw these sub-fram connectors and am considering adding them for stiffness. What do you guys think. Wouldn't they have a similiar effect as the torque boxes?
http://johnsmustang.com/Catalog/2406/
Old Jun 15, 2006 | 07:13 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I added a torque box to the PS of my 67. Just thought it would be a good idea since I was doing the whole car anyway.
Old Jul 10, 2006 | 10:46 PM
Halz5's Avatar
Halz5
I am currently redoing the entire passenger side, bought the frame rail, shock tower, fender aprons, toe board, radiator support... its all taken apart and for the life of me i dont know where this torque box goes. Any help here?
Old Jul 10, 2006 | 11:09 PM
1965MustangFastback's Avatar
1965MustangFastback
The torque box goes under the toe board right under your feet!
