Want to keep factory tach.
Old Jun 12, 2006 | 06:03 PM
chicob73's Avatar
chicob73
Default Want to keep factory tach.
Hello. I have a '73 Fastback with the factory tach and gauge setup. I want to add a MSD box to the car but want to keep the factory tach. Is it possible to use the factory tach with a MSD? It looks like the tach gets it signal from the positive side of the coil instead of the the negative side like a traditional tach. Any help would be appreciated.
Old Jun 12, 2006 | 06:26 PM
Twister's Avatar
Twister
Default RE: Want to keep factory tach.
you do not want to run a factory tach with a MSD box, it will fry the tach
Old Jun 13, 2006 | 12:41 AM
69mach1377's Avatar
69mach1377
Maybe the MSD tach adapter is what you need...
Old Jun 13, 2006 | 06:26 PM
chicob73's Avatar
chicob73
thanks... that's what i needed to know.....i was hoping there was a way to make it work, but i guess i'll try to mount an autometer tach in the dash instead. thanks again.
Old Jun 13, 2006 | 08:53 PM
MidNite27's Avatar
MidNite27
^^^there should be a MSD tach adapter so you dont need to buy a new tach to get it to work with ur MSD.
Like this. (was just a quick search)
http://www.sdpc2000.com/catalog/1572...ch-Adapter.htm
Old Jun 14, 2006 | 10:36 AM
jrrhd73must's Avatar
jrrhd73must
ORIGINAL: Twister
NO This is incorrect. I have a 73 with an MSD it will not fry the tach. The voltages are different so the tack will not register correctly. I added a tach adapter and mine works fine and registers correctly.
Granatelli Sales
Jan 20, 2020 12:34 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
96stang3.8
Sep 10, 2015 06:42 AM
