Timing Chain/Gear Question
Old Jun 19, 2006 | 09:14 AM
Hettar's Avatar
Hettar
Default Timing Chain/Gear Question
Hey,
I'm rebuilding my 289 and have replaced my stock cam with the Edelbrock Performer RPM cam. I'm going to buy my new timing chain/gear this afternoon and had a couple of questions that y'all might be able to help me with.
1. Edelbrock easy step by step directions says I need to match a Edelbrock Performer Link chain/gear with my new cam. Says if I don't, I'll have trouble setting the time. Can I assume the good folks at Edelbrock are just trying to sell me some more of their fine autoparts? Reason I asked is that in the Summit catalog, Edelbrock's chain/gear is $59.88 and Summit's is $20.95 for standard and $35.95 for roller. Sorta big difference in price there.
(Sames goes with the valve springs, they say I need to swap out my springs with theirs, but seeing as I just had the heads rebuilt and the springs replaced, I thing I'm gonna stick with what I just got)
2. If I go with the Summit gear/chain, I have the option of "standard" and "roller" types. Do I assume I want to go with the "roller" type?
3. The Summit roller type and the Edelbrock gears have keyways for "standard", "4 degree advance" and "4 degree retard". So, what does 4 degrees one way do for me?
Thanks!!
Old Jun 19, 2006 | 03:52 PM
428coupe's Avatar
428coupe
Default RE: Timing Chain/Gear Question
I would listen to the Folks at Edelbrock. Sounds to me like you are wanting to put good quality parts in your rebuild, so I would take their advice if I were you. In my opinion, your valvetrain should be a matched set with matching components, preferably from the same manufacturer. Reason is, the alignment mark in the timing set will be aligned to that particular cam. Valve springs are typically another component that should be matched to the cam. Different cams require different valve springs with different spring pressures, etc. On the engine I am building, I had a set of newly rebuilt heads, but when deciding to go with a higher lift cam, I bought the complete cam kit, which included cam, springs, retainers, locks, lifters, timing chain, etc. JMHO
Old Jun 19, 2006 | 05:23 PM
slickman's Avatar
slickman
I just went through all this. You don't have to get Edelbrocks stuff but, I would install a double roller type..
ORIGINAL: Hettar
Hey,
Thanks!!
Old Jun 19, 2006 | 05:47 PM
Hettar's Avatar
Hettar
Thanks for the info... Slickman, did you use the 'standard' key holder on the small sprocket?
Old Jun 19, 2006 | 05:49 PM
slickman's Avatar
slickman
Have not got to that point yet but, I'll be installing it straight up..
ORIGINAL: Hettar
Old Jun 19, 2006 | 10:40 PM
fast66's Avatar
fast66
There are two reasons many timing gear/chain sets have various keyways. One is to give the option of advancing or retarding the cam timing (to raise or lower the power band in the rev range)
The other reason is so that when you properly set your cam up using a degree wheel and dial indicator, you can set it accurately, and correct any machining errors. Have a look at the edelbrock website, it gives great info about how to degree in a cam.
Old Jun 19, 2006 | 11:27 PM
slickman's Avatar
slickman
And some of that will vary from one cam manufacture to the next. Comp Cams for example has an advance already built into them when you install them straight up.
ORIGINAL: fast66
Old Jun 20, 2006 | 01:36 PM
Hettar's Avatar
Hettar
I checked out the install instructions on the Edelbrock website and they answered it in one sentence...
DO NOT install a Performer-Plus or Performer-RPM camshaft in an advanced or a retarded position.
CarrieS
Sep 1, 2015 01:00 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
