Coil over conversion
I have been thinking about doing a coil over conversion. BUT, all the kits I have found are WAY to pricey for me. Has anyone found a place that does not have their heads in the clouds trying to make a killing?
That's another one that is WAY too much $$$$.. They would sell allot more if the prices were reasonable.. They just don't get it..
ORIGINAL: grocery getter
coilovers? i'm still trying to come to grips with $1200 to $1800 for a rack setup
I'll have to check.. I don't mind spending money as you know soaring with all the stuff I have doing to my 66. But anything over $800 for a coil over or a rack and pinion setup is too much $$$.
ORIGINAL: Soaring
Have you checked with Summit? Looks like really good prices to me.
The one thing I'm not sure of is if I can use my stock column with a rack setup. I do know some year the steering box and shaft that goes through the column is one unit. Not sure what that was. If you're sample below is right, if I can use my stock column, I can get the rack setup for $350??
let's use this one as an example:
retails for about $1690
rack 350.00
column 400.
$ 900.00 + for the cradle and hardware?
rack 350.00
column 400.
