Had a bad night
Old Jun 24, 2006 | 02:51 PM
  #21
atomsk680's Avatar
atomsk680
Default RE: Had a bad night
ouch, get better soon, i once burned the side of my arm on my muffler last summer when changing a tire on my fox. i learned to make sure not to lose those nuts for the tires, cause they roll.
Old Jun 24, 2006 | 07:47 PM
  #22
Scott H.'s Avatar
Scott H.
You, my friend have good wife!
The round copper wax container in the base of the thermostat faces in to the manifold, so that when hot the valve opens in towards the manifold, away from the neck. Paint on the neck of the housing may have been disolved by the heated coolant, and actually worked like a grease. I'm still suprised that if the clamp stayed on the hose, the whole thing was pliable enough to go past the rib at the end. I would take a close look at that clamp. Properly tensioned the clamp band should cause a slight, and even, indentation all the way around the hose, so that the band is fairly flush with the outside hose diameter. There is a torque spec for the clamp, but for the life of me, I can't remember what that is.
I'd pressure test the cap to make sure the blow off point is within tolerance. Sometimes brand new caps and thermostats, need to have the valves worked by hand once, just to break them free. I'm not a big fan of opening the thermostat valve w/o heat, however, I've done it many times with no ill effect (knock on wood).
The '66 doesn't really trap air, but anything is possible. If you would, please let us know if the paint on the neck feels gooey. In either case wash the hose out real well with soap and water,and wipe the hose out one last time with a clean dry towel, just to make sure. Use a solvent to remove the paint on the neck, and then soap/water. Better overly safe than have another disaster.
You can probably have a local place pressure test your cap for free. Especially after you tell them what happened! Takes less than a minute to do.
As for the thermostat, put a pan of water on the stove. Toss in the Thermostat add a thermometer and cook on medium until tender.....Uh wait, I meant warm up the water until the thermostat opens and note the temperature. Should be within 5 degrees of rated temp.
Let us know how it all goes. Would be a very good closer to be able to post the what and the why of this incident.
Scott
Old Jun 24, 2006 | 08:39 PM
  #23
slickman's Avatar
slickman
I have a funny feeling that the clamp was bad or it was not tight enough..
ORIGINAL: Scott H.
Scott
Old Jun 24, 2006 | 08:42 PM
  #24
Clu7ch's Avatar
Clu7ch
ORIGINAL: slickman
+1
but i also believe there was excess pressure, paint on the housing creating a smooth surface and it being lose allowed coolant to act as a lubricant. it was a bit of a chain reaction if you ask me. even with a lose clamp, the hose shouldn't have popped off. it would leak, but shouldn't fly off.
Old Jun 24, 2006 | 10:54 PM
  #25
dcohen's Avatar
dcohen
i feel your pain man, ive had 2nd degree burns on my face too, not fun. i didnt even get any morphine, so consider yourself lucky there. As for the car, it can be fixed, would insurance cover something like that?
Old Jun 25, 2006 | 02:40 PM
  #26
1965MustangFastback's Avatar
1965MustangFastback
Why would paint have anything to do with it? What about chrome housings? Can't get any smoother than that, I have a feeling it was the clamp, The original housing have a texture and rib at the end, so I can't really see it being the paints fault! Hell, I just took off mine, it too was painted, and I never had any problems with it coming off!
Old Jun 25, 2006 | 04:52 PM
  #27
Clu7ch's Avatar
Clu7ch
ORIGINAL: Clu7ch
ORIGINAL: slickman
+1
i said it was a combination of things. not solely the paint. if you have a lose clamp, before your system builds pressure up, you should leak fluid. even if you need to build pressure up, it shouldn't hold that much pressure to do that.
Old Jun 25, 2006 | 05:18 PM
  #28
Soaring's Avatar
Soaring
I ♥ Acer
Just be sure you have a 13 lb. cap and not any higher.
Old Jun 26, 2006 | 12:14 PM
  #29
cormy's Avatar
cormy
That is scary. You just don't think something like that will happen while working in your garage. I had a similar situation in college quite a few years back. I had a FIAT spyder I was driving to school with sandals on when the heater hose coming to the interoir blew and sprayed my feet and ankles with boiling antifreeze, I still remember how much that hurt. Hang in there, you'll heal.
Old Jun 27, 2006 | 02:21 AM
  #30
earlymustang's Avatar
earlymustang
I'm lucky and just thankful it didn't mess up my eye. Everything else will heal.....eventually.
ORIGINAL: cormy
