Help installing Sun Super tach
Old Jun 24, 2006 | 01:29 PM
  #31
19stang66's Avatar
19stang66
Default RE: Help installing Sun Super tach
Thanks mr negative. I betcha $10 bucks your wrong buddy.
Old Jun 24, 2006 | 07:55 PM
  #32
Scott H.'s Avatar
Scott H.
OK, so now we are going to want pictures of your install job. I have faith that you will do an excellent job!
BTW: just in case you are wondering. The way the original tach was installed by Ford (or dealer), was to disconnect the pink lead at the bullet connector, then the tach lead plugged into that, another lead coming back out of the tach plugged into the pink resistor wire. This is why in the original configuration, if the tach took a dump, you lost power to the coil, and the car died as well.
The way I am showing you to do this, and the way the new repro tachs work eliminates this issue.
When I said it was the correct way, I wasn't just guessing.
I've got a cyber 6pack of Henry's Rootbeer betting on you. Make us proud!!!
Scott
Old Jun 25, 2006 | 12:52 AM
  #33
19stang66's Avatar
19stang66
haha I wont let you down! I'll hopefully finish her up tomorrow. Gotta going away party to attend for my buddy who's leaving to the Naval Acad. in two days.
Old Jun 25, 2006 | 08:45 PM
  #34
19stang66's Avatar
19stang66
Well I went and got some "bullet" connectors from ACE and figured out that they are way to small to fit the bullet connector for the pink resistor wire. ACE only had one size of these connectors. Do they only make one size of bullet connector? The 18-22g and 14-16g have the same sized "bullets" on them. Where can I find the right sized ones? I am thinking of going to Best Buy (electronics store) and asking them.
Old Jun 26, 2006 | 02:25 AM
  #35
Scott H.'s Avatar
Scott H.
I doubt if Best Buy will even know what you are talking about. Ace hardware or Napa *may* have them. If you have an awl or a pick you can open up the bullet on the ones you have, until they plug in nice and tight. That will work fine for what you are doing.
I got my stash through the guy who supplied all the nuts and bolts for a local dealership. Can't remember if it was Lawson, or Kar Products.
Scott
Old Jun 26, 2006 | 04:49 AM
  #36
19stang66's Avatar
19stang66
damnit why didnt I think of that. I got nothing accoplished today because I thought i'd have to go find other ones. I'll try it tomorrow. Thanks.
Old Jun 26, 2006 | 07:23 PM
  #37
19stang66's Avatar
19stang66
WOOO IT WORKS! Finally got all the connections made and started her up! Thanks a ton Scott, couldnt have done this nice of a wiring job without you. Enjoy your Rootbeer!
Oh and I found the three hole plug for the lights, and it works also! Now I can hook up my oil pressure and water temp gauges to that too.
Old Jun 26, 2006 | 07:35 PM
  #38
Scott H.'s Avatar
Scott H.
Sweet!
Glad to hear you made some serious progress there.
Congratulations on an excellent job!
We'll share that 6 pack, and have a cyber rootbeer salute [sm=icon_cheers.gif]
Scott
Old Jun 26, 2006 | 07:59 PM
  #39
67t5ponycoupe's Avatar
67t5ponycoupe
I guess Mr negative was wrong again. I'm glad you got it going. Good job and congrads.
Old Jun 26, 2006 | 09:31 PM
  #40
19stang66's Avatar
19stang66
haha thanks 67t5. I have nothing against you it was just that Scott had the facts and his job deals with this kind of stuff so I figured he had to be right.
[sm=icon_guiness.gif] mmmm it sure tastes good!
