aftermarket guages
Old Jun 23, 2006 | 04:45 PM
slick66stang's Avatar
slick66stang
Default aftermarket guages
i bought a set of aftermarket gauges for my car. oil volts and temp from autozone. i was wondering if i could splice in the power to all three gauges from the battery or solenoid. and ground it out under my dash.
Old Jun 24, 2006 | 08:20 PM
Scott H.'s Avatar
Scott H.
Default RE: aftermarket guages
I'd suggest using a test light to locate an accessory tap. Look around your radio area, there should be one there that has power with the key in Acc/On. Get a large nose bullet connector and plug in there for positive. Also there should be a dash light tap around the ignition switch area that you can use for the light circuit. This will allow you to dim your gauges along with your dash gauges.
The negative leads for the lights can be tied together and grounded to the dash with an eyelet connector. you can use the screw that holds the pod to the dash as your ground point. I'd suggest a low amp inline fuse. The instructions should tell you what amperage is suggested.
Now you only have the leads to the senders themselves to run. If you are not going to use the gauges in the cluster, you can disconnect them at the cluster and use those wires. This saves running wires through the firewall, and the associated ugly mess that comes with it.
HTH,
Scott
Old Jun 24, 2006 | 08:31 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Scott H.
HTH,
Scott
and don't forget the constant power from a hard wire (direct line to the battery) will drain b/c it's on all the time.
Dan04COBRA
Sep 30, 2015 11:46 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
96stang3.8
Sep 10, 2015 06:42 AM
