gas pedal spring install help
Old Jun 25, 2006 | 01:01 PM
  #21
69mach1377's Avatar
69mach1377
Default RE: gas pedal spring install help
ORIGINAL: Soaring
I'll be damn. I learn something every day. Mine doesn't have that, so I guess it was taken off years ago. My pedal flops a little from left to right, but not enough to worry me. I have just figured all these years that was just the way it was supposed to be.
Same here...I guess I should see if mine is there. I tend to use mine in digital form though, on or off. Is there an in between?
Old Jun 25, 2006 | 09:15 PM
  #22
66 Hardtop 5.0's Avatar
66 Hardtop 5.0
[/quote]
[/quote]
Only when starting the engine...
Old Jan 19, 2008 | 12:13 AM
  #23
FastMustang's Avatar
FastMustang
Do you know how to remove the screw to remove the pedal and how to re-install. The pictures helped a lot as far as the position of the spring. Thanks a lot.
Old Jan 19, 2008 | 12:27 AM
  #24
ky's Avatar
ky
America ftw
theres a pin holding the bolt in.
you fail though. this thread is like a year old.
Old Jan 19, 2008 | 12:57 PM
  #25
67t5ponycoupe's Avatar
67t5ponycoupe
Mine didn't have a pin. It was just a phillips screw that you get to from the left.
Old Jan 19, 2008 | 01:02 PM
  #26
FastMustang
ORIGINAL: true66gt
I'll check for the pin. Thanks.
Yeah I noticed the thread was old but thought i might as well add to it instead of starting a new one.
Old Jan 24, 2008 | 03:23 PM
  #27
FastMustang
ORIGINAL: 67t5ponycoupe
67t5ponycoupe,
Mine has a phillips head on the right which goes through the back mounting of the pedal and looks like it screws in to a bolt, but the problem is that I cannot unsrew the phillips the bolt keeps turning and i cant get a grip on it. its not a hex bolt just plain round. I saw no pin
any advice as how to get this out?
Old Jun 12, 2011 | 07:40 PM
  #28
skinnydog4's Avatar
skinnydog4
I need a pic of that also been having trouble w/ gas pedal spring..
Old Jun 12, 2011 | 08:06 PM
  #29
rmodel65's Avatar
rmodel65
Yukon Cornelius
necrothread revival! at least you use the search function lol
Old Jun 12, 2011 | 08:07 PM
  #30
skinnydog4's Avatar
skinnydog4
it is an accelerator pedal spring part # 9760 for 65-68 mustangs
