Question for MyShifter
Old Jul 2, 2006 | 10:23 PM
Clu7ch's Avatar
Clu7ch
Default Question for MyShifter
what are those things you have atop your valve springs and what improvements do they make you the valve train?
Old Jul 2, 2006 | 10:25 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Question for MyShifter
A pic would help then any one could answer
Old Jul 2, 2006 | 10:29 PM
myshifter's Avatar
myshifter
I ♥ Acer
stud girdles, helps keep valvetrain flex down, as opposed to using shaft mounted rockers
Old Jul 2, 2006 | 10:31 PM
Clu7ch's Avatar
Clu7ch
how do they work opposed to the rockers? you have pics? trying to look at them in your sig is a little un-nerving. LOL!
Old Jul 2, 2006 | 10:36 PM
myshifter's Avatar
myshifter
I ♥ Acer
you use regular rockers like always, the girdle ties all the rocker studs together to eliminate any one stud from flexing under high rpm and heavy spring loads. On that motor open spring pressure is around 615lbs, without a girdle, the rocker arm studs have a tendency to flex and alter the calculated valvetrain
Old Jul 2, 2006 | 10:43 PM
Clu7ch's Avatar
Clu7ch
okay, noiw correct me if i'm wrong here. the cam pushes against the pushrods (i guess that's what they are called), the pushrods push up on the rockers, the rockers push down on the valves and open them to let air/fuel in/exhaust out.
the girdle keeps both sides from flexing, the pushrods and the valves?
Old Jul 2, 2006 | 11:00 PM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: Clu7ch
it keeps the rocker arm stud from flexing when the pushrod is trying to open a 600lb spring
Old Jul 2, 2006 | 11:07 PM
Clu7ch's Avatar
Clu7ch
okay and the rocker arm stud is the part that gets pushed up by the cam and opens the valves?
Old Jul 2, 2006 | 11:23 PM
myshifter's Avatar
myshifter
I ♥ Acer
no the stud is screwed into the head and holds the rocker arm which will push on the valve tip and open the valve
Old Jul 2, 2006 | 11:27 PM
Clu7ch's Avatar
Clu7ch
oh, okay, i see now. thanks man!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
