Help....Just bout a 67' Coupe
Old Jul 3, 2006 | 02:11 AM
juspay4speed's Avatar
juspay4speed
Default Help....Just bout a 67' Coupe
Just bout a 1967 Coupe, has a 289 with 302 heads (supposedly), 3 Speed manuel Transmission. the car has been sitting in a "backyard" for about 11 years, just pushed it up on the trailer and havnt started anything on it yet. the engine isnt locked up, but where do i start? also is it possible to get keys cut at the dealer with a vin #?
Old Jul 3, 2006 | 02:17 AM
67Sally's Avatar
67Sally
Default RE: Help....Just bout a 67' Coupe
Do you have any pics? Is there a lot of rust? Are you planning a restomod or a restoration? I think the best approach is to just strip the entire car down in most cases if you're looking for a really clean build.
Old Jul 3, 2006 | 02:19 AM
6mustang6's Avatar
6mustang6
no, If you dont have any keys.... You can get a locksmith to come out, and cut you a set of keys.
Old Jul 3, 2006 | 03:32 AM
grocery getter's Avatar
grocery getter
rebuild the carb . replace the fuel pump. change the fluids. replace the battery. pull the plugs and squirt some oil in the cylinders
check the brakes before you drive it.
Old Jul 3, 2006 | 03:34 AM
atomsk680's Avatar
atomsk680
ORIGINAL: juspay4speed
you need a locksmith for the keys. how much did you pay? is there alot of rust being that it has been outside for 11 years?
Old Jul 3, 2006 | 05:39 AM
Clu7ch's Avatar
Clu7ch
ORIGINAL: 67Sally
yeah, a full out resto is an excellent idea for a car that has been sitting for that long. pull everything, strip the interior. more than likely you will find a bit of rust damage to the floor pans. you should replace them. also strip the paint and see if anything has been done previously/is hiding. and as grocery getter said, check the brakes before anything. than when you go t to put it back together, start with suspension, than brakes than motor/trans/drive line, than interior. what good is an awesome **** interior if you can't controll the car?
Matt's 95 Stang
Oct 5, 2015 07:16 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
uberstang1
Sep 20, 2015 06:42 PM
Sep 17, 2015 07:32 PM
