MSD?...
Old Jul 5, 2006 | 10:14 PM
ADRIAN1's Avatar
ADRIAN1
Default MSD?...
i have a 289 that i want to start modding up. i want to get m=MSD ignition system but i dont know what model or package to get. i need [sm=helpout.gif]...
Old Jul 5, 2006 | 10:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: MSD?...
explain your reasoning for getting the MSD.
Old Jul 5, 2006 | 10:31 PM
65BlackSunshine's Avatar
65BlackSunshine
Default RE: MSD?...
The 6A is the street application one you want, if you have a stick go for the 6AL as it has a rev limiter that you can set to help when you miss a shift.
What Soaring is probably get at is for $200 you can do a good number of mods to your car that might increase your performance better. While you can toss a bunch of the advertised names on any engine, you really have to engineer the motor with specific goals/ideas to get the most out of it. Just because something is the best (not saying MSD is) does not mean you need it.
Old Jul 5, 2006 | 10:55 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: MSD?...
I presonnaly think that MSD is over priced over kill for a street engine. The amount of performance you get from one does not justify the cost. A good electronic conversion with a good coil will get you the same performance on a street engine. Anyone concur?
Old Jul 5, 2006 | 10:59 PM
ideal_mustangs's Avatar
ideal_mustangs
Default RE: MSD?...
I agree. I see no need for an msg ignition. You can take the ignitorII and the 40000 volt coil and do a lot. I still run points and do just fine though.
Old Jul 5, 2006 | 11:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: MSD?...
You won't believe how much more efficiency you will get with the Pertronix over the points.
Old Jul 5, 2006 | 11:36 PM
mustanglover66's Avatar
mustanglover66
Default RE: MSD?...
I have MSD in mine and love it I've got the 6AL and a mech. advance billet dist.# MSD-8582 with the blaster 2 coil. I am also running 9mm ford motorsport wires. With this set up its never missed a beat and always starts quickly with out using the choke. I have a manual choke and plan to get rid of the vacume secoundary on the carb when I rebuild the engine. When I do nothing on the car will need vacume which is a good thing because the engine will not have much at all at idle.
Old Jul 5, 2006 | 11:41 PM
67t5ponycoupe
Default RE: MSD?...
Ok the question of the hour is, how much money do you have in your MSD set up? It ain't cheap is it?
Old Jul 5, 2006 | 11:53 PM
mustanglover66
Default RE: MSD?...
No its not cheap at 178.95 for the dist 33.95 for the coil 39.95 for the wires 168.95 for the 6AL but I will never have to upgrade for any future mods
Old Jul 6, 2006 | 02:51 AM
6fivestang's Avatar
6fivestang
Default RE: MSD?...
where did you buy your stuff MUSTANGLOVER66
