Rear brake line?
I have a 66 fastback with drum brakes. Looking from underneath from the rear above the Left side of the differential the left brake line and right brake line join at a union and it looks like a vent off the top, that on mine just goes to an empty hose. Can someone tell me what this is? Is it an over pressure line that dumps the fluid? I have good line pressure, so it can't be venting fluid. Any help would be appreciated. thanks
Can you post a pic of it? It sounds like a proportioning valve. Its sense your vehicles ride height and adjust rear brake pressure accordingly. So when the car is loaded down itll allow more force to be applied to the back brakes. Im not positive if thats what youre talkin about, but thats what it sounds like.
-P.
-P.
He's probably talking about the differential/axle vent tube. Not anything to do with the gas line. It's a rubber hose going to the ground, right? And the vent is on top of the axle on the driver's side of the pumpkin, Right?
Don't know bro, but my hose has been rotted off for years. I see no real reason to even have a hose on it, except for may keeing dirt out of the vent. I guess I will have another project tomorrow. New hose on my axle vent.
My vent is directly on the pig. No tubes or anything. The only factory vehicles Ive seen with actual rubber hoses for differential vents are jeeps. And he did mention a brake line in his description, so I was thinkin braking system not drivetrain.
-P.
-P.
