Rear brake line?
Old Jul 6, 2006 | 08:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rear brake line?
Just so we are all on the same sheet of music, is this what we are all talking about?
[IMG]local://upfiles/10034/74A60B8B1B714BB0917071F9D63DBD16.jpg[/IMG]
Old Jul 6, 2006 | 08:21 PM
67t5ponycoupe's Avatar
67t5ponycoupe
That is what I have been talking about. Looks like yours is broken Soaring. The clamp is still there.
[IMG]local://upfiles/27838/348BA647503E44028C58AA7E2A347B10.jpg[/IMG]
[IMG]local://upfiles/27838/91718E0D97A74636B76F226807DC7C82.jpg[/IMG]
Old Jul 6, 2006 | 08:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, that's what I said. My hose is rotted off. I need to replace it before I decide to use Ol' Yeller for a ski boat. Your vent hose seems to go up into something on your 9 incher. Where does it connect. Also, you definitely need some brake shoes bro.
Old Jul 6, 2006 | 09:20 PM
67t5ponycoupe
The brake shoes are good and fat just a little surface rusted. They will work for now. The hose goes into a hole in the chassis by the left shock. See if I can find a pic. It is held in place with a clamp that screws down to the chassis. The hose goes in the top hole and the clamp bolts to the bottom hole
[IMG]local://upfiles/27838/1D38EAF48343429485C527E014AF2B68.jpg[/IMG]
[IMG]local://upfiles/27838/263E5610BBBD47858D876A9A80F1A6A6.jpg[/IMG]
[IMG]local://upfiles/27838/42E27AE2AE43421DBC821897ABD8EA96.jpg[/IMG]
Old Jul 6, 2006 | 09:34 PM
6mustang6's Avatar
6mustang6
Yeah, i kinda tore mine off a long time ago, trying to figure out what it was. Well, i have known what it was for quite awhile now.
Old Jul 7, 2006 | 02:43 AM
baddog671's Avatar
baddog671
Where does it go after it goes into the undercarraige hole? Just up under the seat?
Old Jul 7, 2006 | 02:46 AM
67t5ponycoupe
No it is just a pocket. It doesn't go inside the car.
Old Jul 7, 2006 | 02:49 AM
baddog671's Avatar
baddog671
Oh, ok. Thanks!
Old Jul 7, 2006 | 12:37 PM
bubs66's Avatar
bubs66
Soaring has the picture of what I am talking about. Since both the left and right brake line screws into it, I assumed it had something to do with the brake lines. But it is connected to a hose that is about 12" long and this hose is tucked into an opening of a steel frame crossmember. Since it wasn't leaking fluid, it makes sense that its just a vent for diffential. thanks for the help.
Old Jul 7, 2006 | 03:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
I went out to the garage to replace the hose this morning, and to my surprise, the hose was still there, just not hooked up. After getting the clamp off, I took it into the shop and pryed the old hose end out of, spread it slightly, then reattached the hose by using the same clamp. So, that was a cost nothing project. It's not often I have cost nothing projects.
[IMG]local://upfiles/10034/E127342DCFC04A0A850650DBB1B2AAEF.jpg[/IMG]
musnicki
Sep 23, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
