Fan shroud install problems
Old Jul 7, 2006 | 02:39 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Fan shroud install problems
Sounds like it is hitting the shroud due to the torque of the engine. Ya might want to check your motor mounts.
Old Jul 7, 2006 | 05:09 PM
19stang66's Avatar
19stang66
Motor mounts are brand new.
Old Jul 7, 2006 | 08:44 PM
19stang66's Avatar
19stang66
I got the new clutch today and it a lot bigger than the old one. I also got the shroud to stop hititng the fan! But the shaft is shorter on the new clutch so i'm in need of a spacer. Its not that much shorter, but short enough where it doesnt go half in half out. I'll post some pics later. Reroute that hose Soaring?
Old Jul 7, 2006 | 09:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
re-route which hoses bro? They are both on the outside of the shroud as you can see.
[IMG]local://upfiles/10034/B19F056151D14ED38C56B3ED85748AD7.jpg[/IMG]
[IMG]local://upfiles/10034/79EFF77206CA4896B9C2145B041D48CD.jpg[/IMG]
Old Jul 7, 2006 | 09:36 PM
19stang66's Avatar
19stang66
hahaha, the clear overflow hose silly. The one you said you were going to put through the bracket or am I just thinking you said that?
Old Jul 7, 2006 | 09:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
Oh, THAT hose. Yeah I re-routed it today because I liked the way you routed yours. you can see the spillage of fluid where I took off the hose from the rad.
[IMG]local://upfiles/10034/465BA07177614E3F90BB5631336D0D71.jpg[/IMG]
Old Jul 7, 2006 | 10:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
I just spent a few minutes cleaning up the fluid and repainting the area. I did notice that my clear plastic hose has started to harden though. I guess we will have to go with a real rubber hose in the future, huh?
[IMG]local://upfiles/10034/8F3EFA888AD540E39266DD9039D6B6BF.jpg[/IMG]
Old Jul 8, 2006 | 01:11 AM
19stang66's Avatar
19stang66
Yea my hose is kinda turning colors. It's just some clear hose from Menards. I bought a lot of it so if it ever hardens I can just replace it quick. I like the clear so I know that my overflow isnt clogged or something. Thanks for all the help.
Old Jul 8, 2006 | 01:18 AM
19stang66's Avatar
19stang66
here are some pics, notice I went with a new radiator cap Soaring
djbigskrilla
Sep 20, 2022 01:04 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
jjwinel78
Aug 17, 2015 03:34 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
