Weiand stealth Intake
Old Jul 8, 2006 | 12:10 PM
1965MustangFastback's Avatar
1965MustangFastback
Default Weiand stealth Intake
Ok, I finally go to taking my intake off on the 289, now I'm just test fitting everything before sealing it up! When I placed the intake "WEIAND Stealth" on the motor along with the stock Ford one inch spacer and the Autolite 4100 carb and the Chrome repro style air cleaner on, it looks like its sitting higher than my hood! Do I really need this extra one inch spacer?
I was thinking of getting a 1/2 spacer, but I cant find one with the PCV nipple on it! Any other ideas on what I should do next.
[IMG]local://upfiles/16936/9380A60B30CF4839942AE885323EEEBB.jpg[/IMG]
[IMG]local://upfiles/16936/A7A4476A883146B0970C7E9BE3C8E088.jpg[/IMG]
Old Jul 8, 2006 | 12:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Weiand stealth Intake
I don't believe phenolic (or other spacer manufacturers) makes a 1/2" spacer with the PCV nipple. Of course, the stock spacer does have the nipple, but it is 1". Have you researched the various years motor mounts? I know the 65 and 66 were different heights. You need the spacer for a few reasons. One is to prevent vapor lock, and the other is that it enhances low torque and throttle response. I suppose if push comes to shove, you may have to invest in a different hood like the cowl or shaker hood.
Old Jul 8, 2006 | 01:05 PM
Colorado_Mustang's Avatar
Colorado_Mustang
You could just get a heat insulating gasket instead of a spacer. They're about 3/8" high. I know Edelbrock makes one, as do probably Moroso and Mr. Gasket.
Or this.
Old Jul 8, 2006 | 01:10 PM
1965MustangFastback
I can get a .500 or .325 size spacer but like you said its not going to have the nipple for the PCV valve! How else can I set up the PCV valve? Can I use one of the open holes on the intake for the PCV valve?
Old Jul 8, 2006 | 01:36 PM
EmperorOfChicken's Avatar
EmperorOfChicken
lol, nipple tehe. Anway...that is a sweet lookin setup i hope you find that spacer and get it to work....or you could use a 3" Cowl Induction style HOOD!!! Unless of course you're goin for a more subtle look....
Old Jul 8, 2006 | 02:14 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Loose the spacer and run the PCV into one of the many holes in the back of the manilfold.
Old Jul 8, 2006 | 06:05 PM
THUMPIN455's Avatar
THUMPIN455
ORIGINAL: 67t5ponycoupe
Yep there should be more places to attach the vacuum lines. Look around and see what you can use.
Old Jul 8, 2006 | 11:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: THUMPIN455
It's not a vacuum port he is looking for, it's a PCV port other than on the spacer. However, I guess any line into the intake manifold will pull the PCV. Yeah, I know, same thing. The spacer is necessary as I have already explained why so that doesn't solve his height problem, except now he can use a phenolic 1/2 inch spacer instead of the 1 inch. Will 1/2 inch really make the difference between clearance and not clearing on this set up?
Old Jul 8, 2006 | 11:59 PM
jroseman's Avatar
jroseman
i have the weiand stealth on my 67 289 -306. i had the holley 570 avenger with a 4 inch drop base k&n air filter. i had about 1 inch to spare. the avenger has the pvc port in the rear. i don't know what else you have done to beef up the motor but the 570 was way too small for my set up. currently i have the holley 4777 with the pvc in the rear - it works fine. a new carb might be cheaper than a hood - less trouble also.
Old Jul 9, 2006 | 12:29 AM
Soaring's Avatar
Soaring
I ♥ Acer
I was hoping someone would come on here to give advice about a carb with the PCV intake nipple actually on the carb, and the carb will actually work. You stilll need the spacer though.
