Carb back fire!!!! HELP!
Old Jul 9, 2006 | 04:11 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Carb back fire!!!! HELP!
That would be a good idea... since it has the 5.0 cam in it..
Old Jul 9, 2006 | 04:15 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Isn't it the 5.0 HO that runs the Winsor firing order? The regular 5.0 runs the 289 firing order?
Old Jul 9, 2006 | 04:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yes, that's correct. The 5.0L HO engine was used in 1983-1995 Mustangs, Mark VII Lincolns, and some T-birds and Cougars. All Explorer 5.0L engines are 5.0L HO engines as well. They use the 351W firing order, 1-3-7-2-6-5-4-8. Except for the 1983-84 Mustangs, all of these engines are roller cam equipped. They use a reverse rotation water pump and front cover. The 1994-5 Mustang and all Explorers use a unique front cover and water pump.
5.0L Full Size Car.... This engine was used in 1982-1990 Crown Victoria and Grand Marquis and earlier Mustangs. They use the 289-302 firing order, 1-5-4-2-6-3-7-8. Most of these cars are not roller cam equipped, however sometime in the early 1990s they started using roller cams but retained the 302 firing order.
Old Jul 9, 2006 | 06:24 PM
Volcom66's Avatar
Volcom66
YEAAAA! thanks alot guys it was the 5.0/351 firing order! took a load off my sholders! well im going back out there just wanted to say thanks...moparmatt89 i owe you one man
YoungStangsMan
Sep 5, 2015 07:01 PM
Sep 1, 2015 08:16 PM
mtxplod
Aug 29, 2015 01:43 AM
5.0pntydrpr
Aug 27, 2015 10:26 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
