How to install a glovebox?
RE: How to install a glovebox?
Granted, it might not work on all machine screw hole damage applications, especially if the hole is totalally devoid of any thread. On small machine screw application I use fewer strands of the copper. The idea being is that the copper is much softer than the screw and the metal of the stripped hole. It somewhat fills the void area and creats a wedge. The last aplication of this I used was on my acelerator rod. Nearly all the threads had stripped and I could not tighten the bolt that attaches the pedal. I put a strip of 12 guage copper wire through the rod hole, inserted the bolt and tighened it. Just don't overtighten
i used J-B weld and solder flux to repair the holes in mine.... put J-B in holes with toothpick and flux on threads......have removed two times and still holding up!!!! thanx to an old timer for that one!!! you can still learn from the older generation!!!!!! if you listen
ORIGINAL: stangimgood
09-10-2015 08:39 PM
